Results 1 to 32 of 32
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    AGU Misfire, only when hot and under 10psi boost or more.... Coilpacks?
    guys, I've been ahving problems now for a few months with a misfire.
    Strangely, when warming up, and for a few minutes when it's up to temperature, it's absolutely fine, but it seems that when it's been warm for more than a few minutes, the problem starts.
    Driving around slowly, the car is 100% fine, and drives normally, even at part throttle, provided boost doesn't exceed about 8-10 psi, it'll pull right through the revs problem free.
    The problem is, when i floor it, and it boosts over 10-12 psi, it starts to misfire VERY badly.
    i first thought this was due to old plugs, so replaced the plugs with brand new iridium densos. No change.
    I then thought, much like Welly, that it might be the coil pack wiring insulation breaking up, allowing the wires to short. I stripped it all back this weekend, to find all the wiring still perfectly intact, and still very flexible. I retaped it all, and the problem is unchanged.
    This leaves me to think it's the coilpacks breaking down under heat/high load.
    Has anyone ever heard of AGU coilpacks blowing before? under heat and load only?
    id there anyway to tell which coilpack is blown on an AGU?
    Am I able to scan for misfires in VAGcom on an AGU>? module 1 shows no faults at all.
    Any ideas would be much appreciated, I'm off to the ring in 6 weeks, and really need to get this sorted!
    Nick
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Sounds fubar'd to me, best bet would be to try and find somebody to sell it to. Preferably somebody who's close so you can keep an eye on it and make sure its getting looked after...
    I quite often say I'm going to do things.
    Then never do them.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Feck orf Jardo, I'm not selling you my car! (yet)
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Hitachi colis are pretty much bomb proof, but you can't rule it out if you haven't swapped them. Can you borrow a set anywhere? I'd let you borrow mind but I'm away at the moment.
    Can't remember which fuel pump you have, but I'd check that and also your fuel filter.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    I'll see if I can borrow a set of Coils from a mate kev, I'm hoping it's the problem.
    the fuel filter was new about 30k ago, the pump is a 4 bar LCR pump. I think it's unlikely to be the fuelling, as when it's just got up to temp, it pulls perfectly, and records 188g/s maf readings, suggesting around 235bhp. I can't work out how the fuel pump would be effected by engine temperature.
    I did find another very old thread suggesting it could be the ignition amp mounted in the airbox. I guess I need to find a friendly mate with an AGU who doesn't mind me testing out a bit bits.....
    RIP S3dave
    May 2004
    nr Glos
    7,187
    hitachi are'nt fail proof.. better than most but fail just the same in the conditions they have to operate at
    seems most likely coil pack being under boost relatred misfire.
    ign tcs unti might be on the fritz perhaps.. the one which heatsinks into the stock airbox
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Thanks Bill. I'm going to try and ask a friend nicely if I can pop his parts onto mine to see if it cures the issue.
    If it is the ignition module, what's it's proper name? I've always thought it's an ignition amplifier, but to be honest I'm not sure if that's correct.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    The ICM tends to fail on cyl 2 fisrt for some reason. I had a similar issue with coils and ended up playing musical coilpacks on the side of the road till on boost missfire had gone. IE change no1 for a known ghood one, blast a bit, prob exists stil so put pack removed from one into cyl 2 and so on and so forth.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Interesting Mark, I'll find out at the weekend hopefully what's the cause!
    the lovely custard has offered the use of his AGU powered A3 for parts donation. I'll start by swapping over the coilpacks and see if that cures it, and if it doesn't, I'll try the ICM. If that doesn't fix it, I'll scrap the ******* and buy an S3 instead!
    this HAS to be sorted before I head to the ring at easter! Not worth going otherwise.....
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Power Output Stage Module N122. Part number 4D0 905 351
    Homer Simpson
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    What a legend.........
    Apr 2004
    12,523
    Show off
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Awesome, I wonder how much he would want to sabotage one of his coil-packs...
    Then never do them.
    Chugger
    North Devon
    2,716
    probably do it for a bowl of custard or a peice of cake mate
    Custard's Avatar
    Sep 2009
    27
    Hey i never agreed to this ?!?! Prawn just said his guna come round and buy me loads of Custard! i knew it was too good to be true!!!
    frenchman's Avatar
    Dec 2006
    Plymouth
    84
    Quote Originally Posted by Custard View Post
    Remember to stock up for the Ring Dave, no custard in Krautland!!
    Custard's Avatar
    Sep 2009
    27
    Yeah i was saying to james earlier, looking forward to some custard with kissen nugat!
    sorry Nick back on topic
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Byzan A4 View Post
    Show off
    I only know because I thought mine was dicky and I did a bit of research..... lol
    Homer Simpson
    feville's Avatar
    Frank
    63
    My ignition amp went last month (similar symptoms), i changed plugs + packs + had loom all over the place looking for breaks before i changed it....
    Got mine from GSF for 55 + vat
    R-Tech remap - Forge 007p - Forge carbonio - Janspeed catback - N75h - Coilovers - TT comp rims - Powerflex bushes - EBC stoppers
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    cheers dude, the way it feels when it does it, its as if it's more of a general ignition issue than a coilpack problem, which is making me think it's the ignition module and not coils.
    Today it practically created it's own antilag system, started popping at about 2200rpm and the turbo spooled up despite me not accelerating at all :S most bizzare!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Decided I'm sick of this misfire I've been having, and as it only happens on boost, I decided to unplug the N75 to limit boost to actuator pressure only, so 5psi. following something Bill said in Wellys thread.
    The drive is really smooth on 5psi, although obviously it's much slower as there's no mid range torque, the misfire is totally gone, so I can live with it being slow!
    Dyno style plots from VAGCOM are interesting though....
    Here's the plot before the misfire, running around 18psi boost:
    Then here's the plot from this morning, with the N75 unplugged, running 5psi from the actuator, with a tiny bit of creep top end to 6-7psi
    Such a flat curve, with a bizzare almost vtec like kick when the wastegate starts to creep. Drives totally like an n/a car, although still makes impressive top end power.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    In which case, why not buy an MBC and drop the boost to 15.5 PSI. Mine used to do exactly what you describe under full load boost, but it wasn't a misfire.
    Turns out the ECU was calculating MAP pressure via an algorithm and cutting the spark to the coils when it saw too much. This is why it feel sooooo violent when it does it, you almost hit the steering wheel! It only did it at 16 PSI or over.
    I installed an MBC and fiddled with it until it was about right. 15.5 PSI is the charm.
    Homer Simpson
    Sep 2009
    Essex
    2,366
    i cant see the damn pics, but without the massive slug of 20vt torque in the mid range, sounds like a more usable power delivery!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    As mentioned last time we met ... Standalone programmable EBC
    IMO a must have for the AGU engine. Hope you get the miss fire sorted though.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Interesting Welly, but I can't see why it would start doing it after 2 years of running OK! When first mapped it ran at 22psi with no trouble at all, and was proper quick. The turbo has since seen better days, and has a few cracks in the housing now, but up until recently it still ran 18-19psi just fine, and it still does now every morning when it first warms up, it's only when it's been hot for 10 minutes or more that it becomes a real problem.
    Kev: I know an EBC is the future, but I just don't want to spend the money on this shed any more. I'll be looking to move it on towards the end of the year anyway, assuming I don't stack it at the ring sometime in summer.... The mini project is much more important these days
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    In which case mate, disregard. I can't see why it would just 'start' doing it either! Bloody cars!!
    Homer Simpson
  28. #27
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Mine did exactly what you describe on the ko3S when it had a revo KO3 map.....
    Was fine for 2 years on the custard code phase 2 though
  29. #28
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yeah, she's on REVO Stage 1 so that sounds about right. Used to drive me spastic! You'd be mid-overtaking something and the power would just die!
    Homer Simpson
  30. #29
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Quote Originally Posted by HTC View Post
    What are your thoughts on the benefits of gear specific boost and the gain settings Kev?
    I'm tempted to try an EBC, as I'll need one for the Mini anywaym, but I'm not prepared to spend 400 on an AVCR. I've been looking at the Gizzmo EBC, which costs 200, and has 6 programmable settings, but doesn't have the gear specific boost option, or gain control, it just controls the upper limit
  31. #30
    RIP S3dave
    May 2004
    nr Glos
    7,187
    if its flowing "too much air" as far as the MAf's concerned... then some folks try using a 4v7 zener diode across the maf sensor output so it cannot hit the 5v (or close to) threshold where it throws a wobbler
    misfire wise.. new, correct type plugs been tried? I know its stating the obvious, but for me, I chased a similar thing, not imagining it was the plugs (they were'nt old) and bugger me, it cured my then misfire under boost.
    www.badger5.biz
    bill@badger5.co.uk
  32. #31
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    I had been running denso IK22's for 2 years Bill when the problem started, having covered some mileage, i decided to change them again. I went down to my local eurocar parts, who recommended me IK20's for my car, so i fitted them 2 weeks ago, brand new of course...
  33. #32
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Bit of a billy bodge though isn't it really? Surely if the MAF doesn't report correct air flow you will never get correct fuelling....?
    Homer Simpson
