Chris NottAH Fabrications
Results 1 to 28 of 28
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Anyone using DS2500 pads?
    It's time to replace my front and rear brakes on my S3 and these seem to get good reviews so I'm considering them but they don't seem to have wear sensors fitted like the OEM pads do.
    I wondered how people are able to get round this problem as without the sensor installed as I'd assume the pad warning symbol will come up on the dash or log a fault code?
    I'm aiming for a finished setup of:
    DS2500's, braided lines, EBC Grooved discs & OEM gear at the back.
    Any advice (and pointers on where to get any of the above) would be appreciated.
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    Cut the old wear sensor off your brake pads and connect the two wires together, then zip-tie it to your suspension strut out of the way.
    make sure you dont cut the car loom though, because I am sure at some point tou will get pads with a wear sensor again, and will want to use them.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,388
    I'm using ds2500s, they've been on just over 2 years now, and they're only just about half worn!
    Using them with black diamond discs, and the stopping power is brilliant. Don't fade either
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    2 years - That's good going from a set of pads, I'd have expected the more aggresive compound of the DS2500's to wear faster than oem stuff.
    From what i can tell the black diamond pads are a bit cheaper than the EBC ones (only about 25 though) - I was going to get grooved discs based on what I've read about the drilled ones cracking
    S3 AMK
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Are there different types of DS2500 pads or is it just the 1 type? I've seen some and it says 'street' next to them.
    Also, what black diamond discs do you go for? My brakes are so crap!!
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by DJ_Troopa View Post
    I think there's only one type (someone correct me if I'm wrong) and from what I've read there are normal Ferodo pads (marketed as performance street) or the DS2500's.
    I've just had a look at the Black Diamond discs & there are three different types, I'm just going for grooved discs as drilled discs in general can crack between the holes.
    S3 AMK
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    I have yellow stuff pads, never had ds2500s but yellow stuff are good and they come with sensors for pad wear! i have combined with ebc grooved, good combo in my opinion :-)
    It's all in bits
    Apr 2006
    Bristol
    219
    Try Badger5 for pads and discs. Prices on this link
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    I'm currently running Black Diamond Grooved discs and DS2500's on mine and they are more than capable of stoppping an S3 that's been remapped. I've also had them for about two years and they have not let me down once.
    If anyone is interested I will be selling my current set up in the next couple of weeks to make way for a Brembo GT Kit.
    Mineral Grey [
    AMK
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Thanks for the info Maz. Love the look of your car with the S4's btw!
    Do you need to change the rear discs aswell?
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Thanks Troopa, no need to change the rears, OEM discs and pads are fine.
    Mineral Grey [
    AMK
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Cheers matey, will keep this all in mind when the time comes. It had new pads a month before i got the car in october, looks like plenty more to go in them but they're just really weak and i'm scared when i brake sometimes lol
    Feb 2008
    2,817
    bought mine from bill. great brakes, good enough bite from cold and brilliant when hot. i have taroxx g88 discs with mine.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Sep 2009
    Essex
    2,366
    i recommend ebc yellows, had them for years and find them to be great
    as for your brakes........ make sure you put a decent brake fluid in. loads of expensive hardware is pointless without a decent brake fluid
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    Troopa if your scared to brake then you prob have none standard items...unless you do very heavy braking continously?
    my OEM set up hasnt let me down yet but i have experienced minor fade when braking from high speeds then trying to use them straight after for a similar stop.....
    aren't the black diamonds and DS2500 twice the price as OEM?
    Tim
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    I'm not sure what they are Tim. It says the car was serviced in September last year, a month before i bought it. My mechanic has looked at them and said they look pretty much new so i was confused by that lol.
    I don't brake heavy at all. I brake normally, nice and easy, but it takes ages to stop! Feels really spongey!
    Sep 2009
    Essex
    2,366
    sounds like air in the system tbh
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Could be air and may need bleeding but sounds more like water in the brake fluid to me - prob from old fluid
    I'm not normally a praying man, but if you're up there, save me Superman
    RIP S3dave
    May 2004
    nr Glos
    7,199
    DS series pads are the road pads, DS2500 and DS3000 etc are the "race" pads as they exceed reg90 by definition that they are >15% better friction coeffecient than std
    DS3000's on the heavier used S3's work better on the 312mm cars.. DS2500's work for most folks fine tho
    regards
    bill
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Feb 2009
    Aberdeen
    2,623
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Quote Originally Posted by tompearson View Post
    Got mine from Badger5 - fast, easy, good price. Recommend them (or him).
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    I'm running 2500's and ebc turbo groves and they can't half stop when u need them to. Never had any problems and got me out of a few bad moments before now
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    Oct 2008
    114
    I have the Zimmerman perforated discs in the front and back with DS2500 for almost 2 years now. Not torn yet and there is not much brake dust coming of these brake pads.
    When they are torn I will get the same again, because I really like them.
    May 2009
    24
    are there any laws surrounding brake pads that could come into question here I'm assuming that the ds2500 are perfectly legal. But you know what they say ASSuME
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    regards
    bill
    Thanks Bill,
    I think the DS2500's would be more than enough stopping power for me at the moment so that just leaves discs - I read the post you made on seatcupra.net and those 8 grooved discs in the picture look very good - Is there any noticable difference between those and the ultimax discs?
    Also, I'm after some braided lines, are these something you could supply or perhaps suggest a good make / type to go for? (I'm only aware of Goodridge)
    Finally, could you let me know if the prices you quoted on seatcupra.net are still the same please.
    Thanks in advance
    Mike
    S3 AMK
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    Quote Originally Posted by Nutty View Post
    erm ,they could be made of chocolate and be legal as long as the MOT examiner is convinced and they stop the rollers used to test the brakes at low speed
    RIP S3dave
    May 2004
    nr Glos
    7,199
    Quote Originally Posted by MikeA3 View Post
    Thanks Bill,
    Thanks in advance
    Mike
    8 groove are noisier than eliptical or ultimax ones when used hard..
    HEL lines are what I use, all stainless steel construction.
    SCN prices are current yes
    drop me an email to bill@badger5.co.uk if you want more info
    regards
    bill
    www.badger5.biz
    bill@badger5.co.uk
  28. #27
    RIP S3dave
    May 2004
    nr Glos
    7,199
    DS2500's are boxed for race use only, because they exceed Reg90, which states aftermarket pads must be +/-15% of original manufacturer spec.. DS2500's exceed this 15% friction coefficient as you would expect an "upgrade" pad to do.. and they box them as they do to make the buying decision the customers. Reality is they look like any other pad when fitted and work from cold/hot better than OE.
    regards
    bill
    www.badger5.biz
    bill@badger5.co.uk
  29. #28
    Sep 2009
    Essex
    2,366
    another little grey area as well is, at what point do you declare to your insurer?
    what about the muppet on remould ditchfinder gypo spec tyres, does he tell his insurer? i expect the guy on R888s has to.
    when you put non-OEM petrol in. when you replace/upgrade the bushes. when you put better pads or brake fluid in.
