OllieH
Getting these fault codes up all the time in Vagcom.
2 Faults Found:
01539 - Headlights Not Adjusted
35-00 - -
00774 - Level Control System Sensor; Left Rear (G76)
31-00 - Open or Short to Ground
The Ross Tech site lists a possible cause being aftermarket suspension installed. I have the B8's and H&R springs fitted. Should I be looking into this or is it normal with aftermarket suspension. Anyone else got the same?
I'm also getting these:
2 Faults Found:
00878 - Connection to Speaker Front Left
36-00 - Open Circuit
00879 - Connection to Speaker Front Right
Can't say I've noticed the front speakers not working, but will have to check. MIL light not lighting for any of these. Any help appreciated.
2 Faults Found:
35-00 - -
2 Faults Found:
