EM TuningBadger5
Results 1 to 12 of 12
Thread: Bent arm ?
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    Bent arm ?
    The arm in the pic that is bent goes to the front headlight level sensor, what I would like to know is how will having a bent arm like this affect the headlight leveling ?
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    MAYBE IF YOU GOT A HEAVY LOAD IN THE BACK, THE FRONT GOES UP, AND THE SENSOR ATTACHED TO THIS ADJUSTS YOUR LIGHTS SO YOU DONT BLIND EVERYONE?
    soz caps didnt look up till i done!
    Now to many mods to list! Lots of power, torque and Leather!
    Ross_S4
    Aug 2009
    Dundee
    718
    The arm on the rear suspension is straight, the arm on the front suspension is meant to be bent. don't panic.
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    yeah, was looking at mine yesterday when replacing a broken wheel arch liner. Yes its supposed to be bent, unless mine has somehow bent in the exact same way as yours. BTW, is the wheel arch line supposed to be a SOAB to get in out?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    did i just read this wrong or is the geeza asking why the bent shaped arm would have any effect on the head light leveling?? i would of thought its obvious the arms meant to be that shape no??
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Yes it is meant to be that shape. But he was worried that it was supposed to be straight and had somehow become bent, in which case the headlight leveling sensor would be misinterpreting the position and level of the car.
    However, it supposed to be straight, so its fine
    Alex S3 AMK
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    ahh i see... i think ill lay off the fanta!
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    Yeh i thought it was meant to be straight like the rear one.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Where are the arms located exactly?
    Jul 2009
    South Wales
    37
    On the passenger front side, had a look at the car earler and the arm is bent on mine too...
    Ross_S4
    Aug 2009
    Dundee
    718
    There are two sensors, one on the front nearside suspension and one on rear nearside suspension.
    There is a bracket on the chassis with the sensor screwed to it. The sensor has a plastic arm on the side which is bolted to a linkage rod with a balljoint at each end, this drops down to the lower control arm and is bolted on there.
    If you turn your steering hard left and look in the nsf wheel well you will see the front one. At the rear the best way in to it is to jack up the nsr corner, although you can crawl about and see most of it with the car on the deck.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Nice one mate.
