Results 1 to 7 of 7
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Question shell helix ultra oil? G12?
    hi guys and girls,
    I have always used shell helix ultra 5w-30 oil in my 2002 audi s3 and i cant seam to find anywhere that sells it, can anybody point me in the right direction? My supplies doesnt supply it anymore!
    Also, what is the correct procedure to check the G12 coolant levels, should it protected to -20? I have checked it with the engine cold with a coolant gauge and its protected to 0 so i guess it needs more g12. Is it best to top up or completely drain the coolant and start again, if so how do you do it?
    Thanks in advance
    Campbell
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    You should be able to get the oil from the likes of GSF or Euro Car Parts etc
    As for the G12, you can get that as well so I'd get a bottle and do a complete flush if I were you. Looking at the very weak solution that came out of my engine when I changed my thermostat it was no where near enough in there. Now its a fairly dark pink colour...so for the sake of dropping a hose off I'd do the lot again. It tells you the dilution ratios on the bottles
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    can you tell me which hose to take off to drain the tank?
    Sep 2009
    Essex
    2,366
    bottom rad hose would be a good start, ideally you want to get the stat out too to drain/flush the block.
    in the UK you want at least 30% antifreeze
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    can you get to this without ramps?
    Sep 2009
    Essex
    2,366
    definately accessible from the top but it would be less fiddly if you were under the car.
    as for the stat, thats right on the front of the block so simple enough to do. pop a hose in there (and in the bottom hose) to flush all the old stuff out until it runs clear, then youre ready to go
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    There is a tap on the lower right hand side of the radiator on the S3 for coolant drainage and flushing. Well, thats what I always use it for anyway.....
    Homer Simpson
