Volks AutosAH Fabrications
Results 1 to 10 of 10
    Jays Audi Turbo's Avatar
    I Love Boost :-)
    Silsden West yorkshire (hometown essex)
    91
    Unhappy A3 Front Bumper Removal
    Is there a guide on how to remove the front bumper, i cant find anything and i need to know asap??
    London
    160
    there should be screws in the wheel archs and screws under the bumper and plug like clips on the top under the bonnet
    and the whole thing should slide off towards the front of the car...
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Use a wood screw to take the inside part of the lugs on the slam panel out or you'll lose them and it is easy I've done it a few times
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Quote Originally Posted by Cockney Boy View Post
    this is an 8L
    Ross_S4
    Aug 2009
    Dundee
    718
    1 - Torx head screws, there are 4 or 5 on the edge of the wheelarch to remove (helps to have someone else to turn the wheels full left and right for access)
    2 - Open bonnet, there are four plastic rivet type things in a line along the slam panel above the top of the middle bit of the grille (looks like a circle 1/2" diameter with another circle in the middle), screw a small screw JUST into the hole in the centre and pull out the middle bit (about 1-1/2" inch length), then lever up and pull out the larger outer part.
    3 - Underneath the bumper there are two philips head screw to take out. look where the lower grilles are, where the larger middle one meets the smaller outer ones, look at the bottom of the bumper roughly in line with this.
    EASIER WITH TWO PEOPLE! although perfectly manageable by one, suggest you put a blanket or rug in front so when you inevitably lose grip of it and it falls down it won;t scratch.
    get a hold of one end at the wheel arch, pull it outwards from the wing (rather than back or forward etc) until it clears the guides/brackets and then pull it forwards. once one end is out the other end comes out really easily. before you walk off with it to lay it down unplug any front fogs or headlamp washer hoses etc.
    piece of piss. mine almost jumps off on command these days!
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    speaking of bumpers, i have seen a few 8p bumpers on a 8L A3.... what different about the fitment?
    Now to many mods to list! Lots of power, torque and Leather!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Mmmmmmm nice
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    that bonnet looks gay! lol
    i need a new bumper on mine as my mate (previous owner) kissed a bench. Dont suppose you know the work invloved to you voorhees? i think it will look alright without a spastic bonnet. sorry, scope bonnet!
    I Love Boost :-)
    91
    Thanks for the help lads i've sorted it now
