Badger5JMB Retrofits
    Jimdebob's Avatar
    Wantage, Oxford.
    Potential 1st Time A3 Owner Looking For Advice...
    Hello people, im currently looking for an Audi A3 1.8T sport (preferably) and thought you guys would be the best people to ask about things to look out for and pay attention to whilst buying one (potential common problem areas eg. water pumps, turbo's, electrical problems etc!)
    New on the forum and would really appreciate any help you knowledgable forum veterans could give!!
    Cheers in advance!
    James
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Hi James,
    Welcome to the site
    The main things to look out for are a full service history, its not got to be a full Audi history but it helps. The 1.8T will last a long time as long as its had regular oil changes
    When we're on the topic of the engine you want to make sure the cambelt and waterpump have been changed. The thermostat is also a common fault as is the temp sender. You should be able to spot any issues once the cars warmed up. If the temp needle doesnt stand straight up after a drive then the thermostat could be goosed, if the temps up and down a lot it could be the sender thats ranted. Both easy enough fixes but I'd be looking at the engine oil carefully and smelling the expansion tank to make sure the engine hasnt been cooked by someone not getting the problems sorted.
    Keep an eye out for any smoke under load or idle when you drive it.
    Common faults apart from the cooling system can be coil packs and the MAF, these are common but not major issues. If a coil pack is on the way out it'll have a rough idle and might be a bit hesitant when you throttle up. The MAF might cause similar issues too.
    Listen out for clunks when driving over bumps etc, antiroll bar bushes tend to go at about 70K miles.
    Make sure all the electrics work
    Make sure the red LCD in the dash (DIS) works properly so you can make everyone else on here jealous as they tend to fail (not mine though )
    Volume knob on the Audi Concert Stereo can develop a fault (no major biggy though)
    Look out for a good late facelift model with the one piece headlights. These have a revised interior and are seen as a bit more desireable.
    You should be able to pick up a good one with leather, BOSE, climate etc but it might take a bit of looking.
    If anyone claims a car is remapped or has any 'mods' then get them to back them up with invoices etc. A good service history and folder of invoices is a sign of a well looked after car.
    I'm sure I've forgotten loads but someone else will come along and fill you in.
    Oh and make sure you get a 3 door
    Tom
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    A3tom, what signs does the expansion tank show when an engine is knackered?? Coolant colour? smell?
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    You're looking and smelling for any oil or fuel on the cooling system...meaning head gasket failure. Could be caused by a cooling issue leading to a very hot engine (warped head).
    T
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Oh, and it doesnt mean the engines totally knackered, just a failed head gasket.
