Sky InsuranceEM Tuning
Results 1 to 26 of 26
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    squeel at start up
    any ideas what it is? i think its the starter motor not realeasing properly?
    if it is any idea how much a new one is and how easy is it to fit
    basicaly the noise occurs after the starter motor has done its job and the engine does the first turn over (basically as soon as you stop turning the key a second after it will make the noise)
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Prob the fan belt, easy test is spray some WD40 on it, if it goes away then it need tightening
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    surely the fan belt wouldnt do it on demand at start up? it never does it any other time also is a very unique sound
    -AUDI A3 1.8T-
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Its because its cold and maybe because the extra draw of power, im not sure, but i bet it is the fan belt. As i said its an easy test so no harm in trying - i bet everyone else will diagnose the same so prob best to get that one out the way first although we could try another way - how about I think its the ignition module, the starter motor and perhaps the bottom end, change all of those first and then hopefully it will go
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    hahaha ! its been doing it since i got the car last july but its starting to annoy me now! i replace the bottom end first and then let you know lol!
    on a serious note which one is the fanbelt? is it the belts to the left hand side of the engine?
    -AUDI A3 1.8T-
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    i think ill have to take a video though as the nouise is alot louder and less squeeky than a fanbelt, sounds more like a metal spining thing that slips or somthing! hard to explain
    -AUDI A3 1.8T-
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Starter motor solenoid sticking on mate. Common as muck problem with the VAG 1.8 T starters.
    http://forums.vwvortex.com/zerothread?id=2269482&page=1
    This is a DIY fix thread for this problem. My ld starter used to do it. Being a cheapscate I spent a whole 25 for a used one on ebay! Problem solved!
    This is the description of the fault from that thread 'The VW Starter motor has a history of sticking in the start position. This is usually indicated by a loud griding noise following engine start. The noise is usually more pronounced as the weather gets colder. It is caused when the sliding gear train gets stuck and is oversped by the flywheel, and then kicked back into its proper position. Click on the link below in order to hear what this grinding noise sounds like.'
    There is also a sound clip!
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    did you write the haynes manual welly as you seem to know everything! if i ever meet you i ow you a few pints with the amount of times you have helped me out and saved me alot of time! still havent put the new turbo on yet though! gopt all the parts now though! just need to wait for a sunny day! but will let you know how it goes!
    -AUDI A3 1.8T-
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    So is the noise a squeel or a grind??
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    I know the noise - I don't know if you've seen 'Good Morning Vietnam' - but there is a bit when Forrest Whitaker (Edward Garlick I believe his name was in the film) pick Robin Williams up off the plane at the start, he turns the key when the engine is running and it makes a horrible noise - obviously because the engine is running. If you haven't seen it, watch it!!
    That's the noise it will be. It's the same principle - starter moter is briefly staying engaged once the engine is started....
    Homer Simpson
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Lol great analogy, but I have no idea what you're on about lol.
    I only asked as the OP said a squeel, but it changed to a metalic grinding noise halfway thru lol
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Thats fair enough dude, but I know what he means. It's so high pitched it sounds like a squeel and a gring all at the same time. Its such a hard noise to explain!
    It's f**kin annoying though!
    Homer Simpson
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Lol no doubt i'll experience it at some point on mine
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    lol sorry mike! i couldnt find a word to describe it with people knowing what it sounded like! i still would describe it as a squeel but a very loud heavy one haha!
    your input was muchly appreciated either way as you replied in under a min!!
    -AUDI A3 1.8T-
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    lol no problem mate, next time you smell a funny smell let me know (hang on that didn't come out right lol)
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    PMSL
    i will let you know im guessing after a curry!
    -AUDI A3 1.8T-
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    If you want to test the fan belt don't use WD40! Spray a little bit of water on it, if the squeel stops then comes back when the belt dries go and buy new tensioners. WD40 will stop the squeel and diagnose the problem, but then you have a belt covered in slippy, slippy grease...
    Cheap and Reliable is not Fast. Cheap and Fast is not Reliable. Fast and Reliable is not Cheap!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Sure its not the secondary air pump or whatever it is?.
    My car does it in the cold and the squeel is the leaky pump...its VERY common.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Keeno View Post
    Or talc powder.....
    Homer Simpson
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    wd40 dries pretty quick though...
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    WD40 is not grease, its for displacing water (hence the WD bit) it also cleans and yes it lubricates, but if the fan belt is correctly tightened then it won't slip anyway.
    anyway this point is mute as the problem is resolved.
    FYI if ever you've been to a rolling road and you've seen them get wheelspin, guess whats sometimes sprayed on the rollers to stop it
    I'm not normally a praying man, but if you're up there, save me Superman
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    I think I had this problem on mine a couple of weeks ago.
    Started the car... 'EEeeeeeEeeeEeeeeek-Eeeeek-EeeEeeeeEeeeeek' - (also car wouldn't go in to gear?) switched car off!
    Tried to start car again, wouldn't turn over.
    Tried the car again, worked fine.
    Since then i've had a metallic rotating/rubbing noise on and off (various degrees of volume) and a bit of squealing too...
    Bizarrely the noise sometimes stops when you switch off the climate control or stereo?
    Does this sound similar, or could my problem be something else?
    Cheers.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    DJ_Troopa's Avatar
    Back in a turbo!
    Oct 2008
    West London
    1,735
    Visit DJ_Troopa's Instagram Channel
    My last car which was a Lupo GTI used to make this little squeel noise lol sounds emabarrasing! I was told by many people it was the starter motor sticking and it sounds exactly like what you're talking about.
    Inferi Black Cupra K1
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    js150 - i think yours sounds slightly different, it is literally a noise that lasts a second if that! but yer it is embarasing! it doesnt do it everytime but probably about 95% of the time! embarasing if your at a meet or trying to pull a bird and you start your car up and it makes a noise like a dead hedgehog! haha
    -AUDI A3 1.8T-
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    http://www.facebook.com/v/352490671275
    there is a video of what mine sounds like! and before anyone says, i know im out of washer jet fluid haha
    -AUDI A3 1.8T-
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Js1500, yours sounds like mine did when my alternator pully seized.
    Zeebo, Yours is 100% the starter staying engaged. or a worn gearbox bush (which is also a common one)
