Chris NottVolks Autos
Results 1 to 13 of 13
    Aug 2009
    Hertfordshire/Cambridgeshire
    225
    Not to sure about this???
    I dont know if this is a stupid question but this fit my 1996 a3 1.8 turbo (150bhp)
    http://cgi.ebay.co.uk/K-N-APOLLO-CIS...item45df4e179f
    I know its a later model and its the 225bhp but arent they the same engine?
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by audi_a3_turbo View Post
    It would fit, but the routing is a bit different.
    You'd be foolish to spend that much money on one of those though, these are perfectly good enough - http://cgi.ebay.co.uk/NEW-Cold-Air-I...item518ebdaf4f
    I quite often say I'm going to do things.
    Then never do them.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I would not risk that cheap one, its mounted low down where it may encounter more debris and moisture, i also bet the fitration level isnt up to much on that cheap one either.
    The K&N unit will have a much better level of filtration for sure.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Just get some ducting in there for a couple of quid and save your monies
    Oct 2008
    188
    it wont fit anyway as ure turbo intake is 2.5 inch where as the 225 bhp is 3 inch so you would need a custom tip and a bigger maf sensor
    Aug 2009
    225
    right okay then guys thanks for the answers. I want a cda induction kit but I cant afford one!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Dont bother, stock airbox is FINE on our cars mate.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    Quote Originally Posted by Byzan A4 View Post
    The K&N one is mounted in the same place, and there is a plastic guard around and under it to protect it from water and debris.
    My girlfriends been running hers for a while, and Prawns been running one of those for years with no problems.
    Then never do them.
    Aug 2009
    225
    just noticed that K&N do an apollo induction kit for the golf 1.8 20v turbo (150bhp) would this not fit the audi's 150bhp engine?
    http://cgi.ebay.co.uk/K-N-Apollo-CIS...item4cedaf06be
    Apr 2004
    12,520
    Quote Originally Posted by 16Klappe View Post
    The K&N filter unit is mounted higher up, the el cheapo on is mounted on the end of the pipe.
    Stay stock its good for over 350BHP of flow,causes no restriction on my car on it's hybrid
    Aug 2009
    225
    okay then so shoud i just go with the replacement element then? if so which would you recommend?
    Aug 2009
    225
    i just thought that the apollo one looks oky as it is an enclosed unit.
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    Surely that makes no difference if there is a cold air feed going down to where the "el cheapo" ones mount anyway? You can quite clearly see the cold air feed in that photo...By using words like "risk" and "el cheapo" you make them seem ****, when they quite simply aren't.
    From my experience with those I'd spend the saved Ł100 on an F007P instead of an air filter which you don't really need anyway! Because as you say a standard setup if fine for the power anyway, the only reason to fit a filter to an A3 is for the sound!
    Then never do them.
