EM TuningMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 45
    Chugger
    North Devon
    2,716
    Finally... now own an S3
    Hi guys
    Finally managed to find an S3, did quite well I think, facelift 2001 in ming'e' blue with 90k, has bose (which aint as great as i had imagined, RSTT alloys, new tyres, gd service history. Only had to drive 100 miles to get it.
    Got a few things that need doing, the airbag light comes on the dash, the guy said it was the sensor under the passenger seat, fair enough? no doubt a job that needs to be completed by a professional
    He also insisted it was remapped, and the guy seemed genuine, but is there a way of checking? I have vagcom, which I used on a previous car, would monitoring the boost pressure help determine this? It does seem quick, but have nothing to compare too, suppose I could put it against my friends evo and judge it by how much slower it is, lol.
    Also the bloody cupholder is jammed in, and wont seem to come out, this simple to fix or a major operation?
    and driving it back the gauge seem to read about 78oc, which seems low, and from previous posts iv read seems common, probably the thermostat or the sender? suppose I could change stat first, not very expensive.
    While I was looking, was giving up hope and considering getting a leon Cupra R, but im so glad I didnt. I didnt belive it when people said they were more refined than VW golfs, but they obviously are. Hoping to keep this one for a while
    Last edited by sportstractor; 17th February 2010 at 16:48. Reason: because im a dohnut
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Not sure about the cup holder or airbag light dude, but certainly sounds like your thermo is shot. DIY job. 30 plus a bit of time. All fixed!!
    Easiest way to tell if remapped is log boost (Block 115) or air flow (various blocks) on VAG COM and post results
    Homer Simpson
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    My cup holder appeared to be knackered when I bought mine. HOWEVER, try sitting in the drivers seat and tapping it very quickly and lightly. It seems to want to work from only certain angles but has got better over time. Friend of mine in Audi service+parts quoted me 38 quid for a new one. Can't see it being an issue if you are even remotely technically minded.
    Hope this helps.
    James
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Quote Originally Posted by JD09 View Post
    Same here, i think its a common problem, fyi and iirc they are 90 from audi the theiving shytes
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    the piano trim around the cup holder simply clicks out, get a small flat blade at the edge and it will just click away.....you will then be able to remove the cup holder cassette allowing you to clean and/or replace as necessary
    welcome to the site
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Chugger
    North Devon
    2,716
    cool, I better find the vagcom cable then.
    Thought there might be some kind of gypsy trick to the cupholder.
    Hmm, Is that the stat where everybody seems to break the dipstick tube? Cant Wait. I have no doubt its making a difference to MPG then
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    plenty of support on here mate...sounds like your problems are very limited so sure you'll get sorted soon
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by 1animal1 View Post
    Exactly, just don't trust this un ^^^
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by MIKE GTR View Post
    Hmm, pretty sure they were less than that, i.e. circa 30 as I distinctly remember thinking "Ah well" and not putting that cost into my bargaining when buying.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,384
    Glad you've got one at last mate, I really hoped you'd find one and not end up buying Al's evo! good choice
    was it that nice one in Falmouth with the alcantara?
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    sounds to me like JD is a tad intimidated haha...... JD where the hell do you come from, sounds Yorkshire if I had to guess
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,384
    Oh, easiest way to tell if it's mapped is to log MAf readings, Anything over 200g/s is definately mapped
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    http://cgi.ebay.co.uk/2004-AUDI-A3-S...item5886052a98
    Not sure if its the same fitment, looks the same
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    id personally take it off and soak it for ten mins, dry, open it up and have a fiddle whilst drying it - mine did it when i bought - all i did before i knew how simple the trim came off was to clean it thoroughly once i'd coaxed it out, never failed me since
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    Congratulations mate. Welcome. I can't compliment the forum enough. Loads of help when i bought mine... So far I have spent around 500-600 on mine doing everythinig myself... But would have been 900+ if I didn't get help on here.
    The cup holder once out... WD40 ;-) The temprature sensor and thermostat both cost me around 22 from euro car parts for an A3 tdi.
    2001 A3 1.9tdi 130pd (Aka "Osama Bin Diesel") 130bhp 310NM = PMSL
    Done:
    EGR switched off using vag.com. Full no expenses spared service. Refurb Gearbox, new clutch/flywheel.
    In the works:
    Mk II TT Steering wheel (No Airbag), vag.com switchable 3 stage map. Big brake kit. Hybrid turbo.
    Chugger
    North Devon
    2,716
    yeah prawn it was, was a no brainer really. No as quick as evo, but it would be major trouble.
    Just figured how to cancel that bloody speed alert, almost freaked out on the A30.
    Will get it on VAG-COM as soon as I can be arsed.
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Quote Originally Posted by sportstractor View Post
    lol i had that the other day took me a little while to figure out
    s3gav's Avatar
    Jul 2009
    414
    glad to see you found one mate after that muppet with the red one changed his mind lol.
    get some pics up
    SOLD 2002 S3,full black heated leather, bose, 997 turbo's, lcr splitter, coilovers, superchip, blueflame cat back, k&n, forge dv, forge hoses, forge quickshift, forge rear tie bars and forge fmic
    Feb 2008
    2,817
    The airbag light will be the seatbelt sensors. TheY can cost about 100 odd to sort out. Mines the same for a rear passenger seatbelt sensor.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    Hey, i think i've seen that one driving around, I work in Flamouth. It looks pretty smart. I drive a red one
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,384
    Looks very tidy mate, love it!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Welcome to S3 ownership. With regards to the airbag light, try this first. Disconnect the car battery, then under the seats are the airbag connectors, they are yellow I think, disconnect them, spray and clean up with WD40 or electrical contact cleaner, refit and reconnect the battery, then you need to reset the airbag light with vagcom or similar. If the light stays off the next time you fire her up, job done! It's a very common problem with my Passat and S3(same connectors).
    Chugger
    North Devon
    2,716
    yeah gav, what a plonker, i prefer the minge thought
    so is it safe to test the airbag module with vagcom, because i always thought it wasnt advised?
    Prawn, does look mint in the photos, but there is a few bit which need to be sorted. Frenchman (the bastid) pointed out about the centre caps for alloys not being correct, the bloody toad.
    cheers jojo, will definately be trying that one tomorrow. Really dont want to be paying 100, Im going be skint for a few weeks
    s3gav's Avatar
    Jul 2009
    414
    i like the minge to mate lol
    do you mean ming blue?
    looks nice mate
    Chugger
    North Devon
    2,716
    nah i ment ming'e'
    Not got much on today so will be doing stat, and been vag-com ing already, just remember what a bit*ch it is to get it working. Come up with a few faults, one saying to check diverter valve, and another saying comms with alarm siren, which is probably a fuse.
    Can anybody tell me if it is safe to scan the Airbag module with vagcom on an S3, because it comes up with a warning stating it may not be.
    Chugger
    North Devon
    2,716
    ps, iv been told that the rstt centre caps arnt the right ones? and they do look a little odd. So if anybody has any going, give me a PM. Thanks
  28. #27
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    na i think you have early TT ones or something similar...... be a dealer job if you ask me unless you can find sum1 whos dumped their RSTT's...are the wheels originals??
  29. #28
    JD09's Avatar
    Dec 2009
    3,080
    *cough* Ebay *cough*
  30. #29
    Chugger
    North Devon
    2,716
    I dont know if they are genuine.
    Some updates, diveter valve fault hasnt reappeared.
    As advised by JOJO, iv cleaned the airbag connector and cleared the fault, which doesnt seemed to have reappeared. Strange considering there was no sign on dirt or corrosion.
    Also had the cupholder our which seems to have had it, so maybe a new one sometime.
    And went out with a mate, and logged the maf, couldnt get it over 190 g/s, not sure what that means, not remapped?
  31. #30
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Thumbs up
    READ THIS POST!!!!
  32. #31
    Chugger
    North Devon
    2,716
    lol, I had read that post...
    ok, so if 200 is definately mapped, 190 must mean possibly mapped? Standard AMK's log 170 I believe
  33. #32
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Lmao.....your still not taking it in are you
  34. #33
    Chugger
    North Devon
    2,716
    I thought it was a fair question...
  35. #34
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Prawn said if its over 200 then its mapped...not if its over 189
  36. #35
    Chugger
    North Devon
    2,716
    ok ok, are you trying to wind me up? lol
    the key word to the quote being definately... which indicates a lesser amount means possibly. Just read a remaped amk will give 190-210g/s, so it is on the low side. slightly dissapointing as i wanted something quicker than the crustaceans A3... ahwell
  37. #36
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Prawns gonna love you for that LMAO
  38. #37
    superpie's Avatar
    My Mini is Faster than Prawns!
    Barnstaple, Devon, UK
    I still think your a good challenge for prawn matey!
  39. #38
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,384
    hahahahahahahaha. Lolocaust.
    Pretty lame figures hayes, my 200k miles A3 logs 188g/s every time on a Gay03s :P
    Just messing man, at all the RR days I've been to, most mapped KO4 cars have made 235-245bhp, 190/0.8 is 237.5, so it's more than likely had a remap, just potentially a ****e one.
    Still, unlikely to be quicker than the A3 given the 200kg weight penalty :P I guess we will find out on the way to the Ring at easter!
    Pie: your user title offends me. the last time your mini legally went on the roads it had 38bhp, and that was 5 years ago! go back to 16vminiclub.
  40. #39
    Chugger
    North Devon
    2,716
    LOL prawn.
    yeah seems lame but my car is coming up with pressure drop between turbo and throttle. So obviously a boost leak, possibly DV? and this would explain low maf reading i suppose? Just been out and logged requested and actual boost pressure? and there seems to be a 25% drop up in high boost
  41. #40
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Sounds like DV weakened. BEst to get a Forge 007P oin there if not already.
    Mine reads 200g which is about 250bhp...Happy with that. Though i'm not sure how they get the so called 260-265 the map companies advertise?
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
