Monster MotorsportChris Nott
Results 1 to 14 of 14
    Sep 2009
    worcester
    1,097
    n75 to actuator hose
    so as some may remember when i first bought my car it had an mbc plumbed in between the actuator and n75 valve
    obviously i removed this straight away and as a temporary fix i used a plastic connector to join the two ends of the hose and clamped with small jubilee clips, not ideal but was best i could do at the time
    now i want to replace the whole hose to eliminate any chance of leaks etc the hose itself has bends formed into it at certain intervals to follow the contours of the engine etc so rather than buy a normal length of hose and try and clip it to follow the same contours i was wondering if i could buy the proper hose with the bends formed in, dealer maybe? or would it be best to find an s3 breaking?
    hope that all makes sense lol
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Either use a bit of silicon pipe or just order the proper one from an Audi dealer. Shouldn't be that expensive either way tbh...
    <tuffty/>
    Sep 2009
    worcester
    1,097
    wasnt sure if audi would sell something like that, bit of an odd request really but i suppose they must perish from time to time
    watch this space for a price from audi, possibly something outrageous!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Quote Originally Posted by jonny87 View Post
    A popular misconception, as far as I am aware, they list more or less every single part that goes into making a car (they may not have it in stock but can get it)
    Personally I would always at least ask Audi if they can get a part and for a price before trying to find it cheaper... Audi pricing can be a bit bizarre at times but you may be pleasantly surprised how cheap certain parts are
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'd just use a black bit of 4mm internal diameter silicone hose mate if I were you. But 2 metres for Ł3.60 (http://cgi.ebay.co.uk/4mm-BLUE-SILIC...t_1372wt_10020) and replace all the other hoses floating about as well - FPR pipe, DV pipe etc.
    Homer Simpson
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    FPR pipe is 3mm but I got away with using 4mm. It was a bit loose on the connector to the fuel rail but some clamps seem to have made it tight enough.
    Is it easy enough to replace the hoses from the n75 valve?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Westle View Post
    FPR outlet is like a gnat's cock though to be fair! lol.
    4mm should be nice and snug on the N75, it's about the internal diameter of the original pipe. N75 hoses are easy enough to change - the one from charge pipe to N75 is very easy, actuator hose is a bit more fiddly as access isn't great, but not impossible.
    Homer Simpson
    Sep 2009
    worcester
    1,097
    yer but the standard hoses have a very thick wall, 3 or 4mm id say
    the silicone hose is probably only 1 or 2mm?
    would make sense to replace like for like, unless of course the hose is stupidly expensive from audi of course
    ive already replaced the fpr hose and dv hose (when doing n249/n112/sai)
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    That said, it's only ever got to carry enough pressure to open the wastegate so a thick msidewall not 100% needed. Actuator pressure is only about 6-8 psi actuator dependent. The boost hose from the charge pipe to the N75 carries full boost pressure (20 ish) and mine has always been fine mate, no problems.
    But it's up to you duderama! Whatever you're happy with.
    Homer Simpson
    Sep 2009
    worcester
    1,097
    duderama? that a new un
    i think its going to be price dependant, il get my mate to get me a price from audi and go from there
    i wouldnt even like to guess how much it would be from audi, could be a fiver, could be Ł50
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    lol, new 'n improved....
    If a PCV hose from Audi is 20 bucks, which it is , I'd be interested to see how that hose compares....
    Homer Simpson
    Sep 2009
    worcester
    1,097
    right well i went to audi, their diagrams only showed two hoses coming off the n75 valve, they ordered both that were showing in for me and neither were right, one was way too short the other looked like a flipping coolant hose!! so all in all pretty damn useless (those two hoses were Ł20-25 each)
    so i guess il just have to make do with some silicone hose, 4mm id?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    4 MM ID will do the trick for you, and be nice and snug!
    Homer Simpson
    Sep 2009
    worcester
    1,097
    sweet, cheers mate
