Results 1 to 29 of 29
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    Wastegate flutter?
    Hi all,
    I have just had a forge TIP fitted and I seem to have developed a flutter on lift off? am I right in thinking this is very bad? I have a forge 007p recirc valve and it usualy gives me a light woosh sound but now thats completely gone!
    Any help would be fantastic as I'm quite worried at the moment as not sure if this is damaging my turbo?
    Cheers Matt
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,019
    Visit 16Klappe's Instagram Channel
    I'm not sure if it works in the same way with recirc's as atmospheric (in fact I think it doesn't!) but wastegate flutter basically means that the air is passing back through the turbo and effectively stalls the turbo. So yeah it isn't good!
    Does it happen if you lift off quickly? I'm fairly sure that the main cause of flutter is when the throttle plate snaps back quickly, or if the throttle plate isn't opening quick enough you can get a bit as well.
    It's all down to the throttle plate really, try gently working it up to boost by slowly accelerating in 2nd or third up to about 2 and a half/3K and see if you can hear a bit of chatter on the way up to full boost pressure. Let us know what its doing under those sorts of conditions and we might be able to help
    I quite often say I'm going to do things.
    Then never do them.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    hello mate thanks for the reply there is no flutter on the way up or on boost only when lifting off? Could it be down to the recirc valve?
    2002 S3 REVO
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    I'd Just like to add im not driving hard as I have just had a new clutch fitted today also
    Cheers Matt
    2002 S3 REVO
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    I get it and also I know minty has it as well and we are still good
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Thanks Jase I was hoping for a reassuring comment! the work was all done at APS I phoned them and they seem to think its fine also
    Cheers Matt
    2002 S3 REVO
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    A fluttering sound should never be heard from any of the DV's on a 1.8T.
    s3gav's Avatar
    Jul 2009
    414
    mine does it to has done since i fitted my forge dv over a year ago never had a problem
    SOLD 2002 S3,full black heated leather, bose, 997 turbo's, lcr splitter, coilovers, superchip, blueflame cat back, k&n, forge dv, forge hoses, forge quickshift, forge rear tie bars and forge fmic
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    I think I'm going to take my recirc valve off at the weekend and re-fit the original one? might be worth a try to see if theres a problem there, It just seems wierd as its only started today after fitting tip and now lost the boost dump sound?
    Cheers Matt
    2002 S3 REVO
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,456
    Spring in the recirc valve to stiff?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Quote Originally Posted by Andrew@A.L.D View Post
    I was thinking that but its just the standard spring? would it make this flutter if its not dumping properly?
    2002 S3 REVO
    134
    It should not flutter with the green or yellow springs, I would check all the small vac lines, Check the line going to the top of the DV and see if its pulling a vac on idle.
    Nick
    Jun 2009
    Leeds
    3,456
    The valve could be sticking? No or little vacuum to operate the valve?
    Is there any fault codes coming up?
    If the N112 valve is faulty then its may not open the valve?
    FOR SALE
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Quote Originally Posted by R-Tech-Nick View Post
    Nick
    If I were to check this would I just take the pipe off and start the engine an see if its sucking? sorry im not very technical!
    Cheers Matt
    2002 S3 REVO
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Woohoo I've just found a split in the small pipe going into the top of my 007p! Would this be causing my problem? It seems it would!
    Matt
    2002 S3 REVO
    Sep 2009
    Essex
    2,366
    wastegates do not flutter
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,471
    Quote Originally Posted by s3 Hoggy View Post
    Matt
    I would think so... if that pipe is split then the DV won't be working 100% thus not dumping the excess pressure and bringing on the onset of compressor stall which sounds like the noise you are hearing..
    <tuffty/>
    Jun 2009
    Leeds
    3,456
    Arr no vacuum to open the valve, there you go
    Is it better?
    I had that problem with mine were the previous tightened the clip to tight and split the hose
    FOR SALE
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Got a pic of this pipe?
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Is it better?
    I'll get it sorted in the morning and I'll report back, thanks to everyone who's helped out!
    Cheers Matt
    2002 S3 REVO
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Quote Originally Posted by ianysm View Post
    I'll take a pic in morning mate
    2002 S3 REVO
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    If it was, indeed, compressor stall then just have a quick look to see that the turbine hasn't been damaged as the shaft of the KO4's are thin and can't take much abuse.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    How would I have a quick look? Is there an easy way mate?
    2002 S3 REVO
    RIP S3dave
    May 2004
    nr Glos
    7,141
    the k04 will be fine.. sustained high boost no DV then yea I would be more worried, but not like you describe.. You wont observe a thing just looking and touching it
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Cheers Bill
    2002 S3 REVO
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Fixed!!!!!!!!!
    Cheers Matt
    2002 S3 REVO
  28. #27
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    My n249 valve broke which caused the fluttering on mine, plumber the dv direct to the inlet manifold and its fine although the dump noise does sound different, almost like a slight stall but not sure...
    2003 Audi S3 + Go faster bits
  29. #28
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    whilst were on the subject of VAC etc, My boost gauge only reads -4 to -5 psi of vac. on other turboed cars i have had its more around the -20 mark. i dont have any flutter but when i change gear the needle on my boost gauge flutters down instead of just dropping to -20. Why??
    Now to many mods to list! Lots of power, torque and Leather!
  30. #29
    RIP S3dave
    May 2004
    nr Glos
    7,141
    idle vac having a small leak would reduce your manifold vacuum on idle.
    if you have vagcom have a look at block 032 and see what % lambda adjust is doing on short term (first block)... a higher +ve number is compensating for additional air getting in... aka leaky pipe
    (up to 3-5% is probably ok)
    bill@badger5.co.uk
