EM TuningChris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 43 of 43
  1. #41
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    I've got sps+ you need to connect your switch to you laptop and you car at the same time to set the switch up, Then you can customise 3 maps by adjusting Fuel, Timing and boost.
    Cheers Matt
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
  3. #42
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    I used Jasons sps to set my boost to 9 and timing to 7. Ran plenty of logs and 7 is the max I can run. Corrections are simply too high on 8, 9 and 10. Thats with a forge fmic and 99ron fuel.
    Quick enough most of the time but it sometimes feels like the boost is there and other times not quite so much. Going to purchase the liquid display guage so I can keep an eye on what the engines doing more often, going to work etc. Saves me carrying the laptop around with vagcom.
    2003 Audi S3 + Go faster bits
  4. #43
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Had it done with the full revo map and had the settings tweaked, Very happy so far, going to fit the 4barr fpr and have it adjusted to fit
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
