AH FabricationsJMB Retrofits
Results 1 to 23 of 23
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    clonk under sudden sharp braking
    front near side. just notice clonks if i hit the anchors a bit sharpish. passes an mot a month ago. any ideas??
    Now to many mods to list! Lots of power, torque and Leather!
    Lilgaz's Avatar
    Vorsprung Dirk Kuyt
    Oct 2008
    North West England
    23
    Just out of curiosity what was the weather like/road conditions? only I`ve had that happen on two occasions, once over a year ago, and again in the last cold snap around christmas when theres been snow/ ice on the ground. It maybe just coincedance but its the only time its happened..maybe to do with the low temperature..although its been a lot colder and not happened..maybe the abs? hope this helps
    Say hello to my little f*ckin friend!
    2002 8L BAM S3 225 / Forge TIP / Forge Breather / Forge 007P Closed Loop Diverter Valve / Green Cotton Panel Filter
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Check your front wishbone bushes and ARB bushes.
    Jul 2007
    60
    Had the same problem with mine, turned out to be Anti-roll bar bushes and linkages, pain in the arse to replace. The cold will affect noise coming from the bushes as they are made of rubber and are harder when cold. A test you you can try is to drive through a pot hole on one side then the other to see if you get the knocking noise. Obviously don't go mental through the pothole as you can do some serious damage, you could ofcourse find one that is massive, drive through it and claim damages from the council, i know a few people who have done this!
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    yeh i think you lot are prob right about it being a bush. Had new wheels fitted and balenced yesterday as well as a full geio set up and i still get a slight wobble at between 70 and 80. it goes away any slower or faster. Its not violent but ever so slight.(almost not there if that makes sense) Dont know if a worn ARB would cause this??
    Jul 2007
    60
    Hmm i'm not really mechanically minded i just dabble and try to save on stupidly expensive mechanic costs but when i had warn anti roll bar linkages and bushes i had no wheel wobble whatsoever even at the cars top speed. Next time you are under the car look for some play in the linkages, you will know if it doesn't feel right. I honestly can't see that causing the problem though unless ofcourse at 70-80 it happens to be the resonant frequency of the linkages but i'm just guessing to be honest. Do you have any play in the steering?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,511
    Are you sure the wheels are tight ?
    Jul 2007
    60
    Just a quick thought, on the wheels you took off yesterday did you notice uneven wear?
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by Byzan A4 View Post
    lmao mark! arse!
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by paulious View Post
    didnt really look but cant say i saw anything obvious. my tracking was well out tho.
    Jul 2007
    60
    Yeah if i were you get those anti roll bar bushes replaced and linkages if needed then see if the problem goes away. The knocking noise will just get worse and worse, it will affect handling too so i've been told.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    cool i will look into it, thanks
    Sep 2009
    worcester
    1,097
    i have a wobble at 80-90ish
    started after knocking car up a kerb
    put new wheels on, new tires, rebalanced the lot and had tracking done
    still pulls the left quite badly and has the aforementioned wobble
    although ive been told i have a few worn bushes etc before the little adventure up the kerb the steering was perfect, straight as anything no wobbles
    if i had bent a track rod end would they not have picked up on this when doing the tracking?
    and i havent noticed a clunk when under harsh braking but i do get a clunk when reversing off my drive and putting it on almost full lock, low speed obviously?
    djb83's Avatar
    redline responsibly
    Sep 2009
    north lanarkshire scotland
    68
    this may sound stupid but mabbye a cv joint ? that could cause the clunk on full lock
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    checked that fella, think it mite me a ARB worn. Ill get on the case payday!
    djb83's Avatar
    redline responsibly
    Sep 2009
    68
    cool mate got the same prob i was thinking cv but i'll chek my arb's soon as
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Feb 2004
    2,036
    Quote Originally Posted by ALPINE View Post
    If it is like a loud twangy clonk, it is almost certainly a sheared engine / gearbox mounting bolt, on the n/s of the car, you may not even realise it as the bolts seize in the mount but also snap so dont hold the mount in lace properly. A lot of drilling out required , tap the threads and fit a new bolt.
    ARb bushes are more just a rattle over potholes and transverse ridges, not really affected by brakes. The broken bolt shows very few symtoms, only the loud single clunk under very heavy or sharp braking. Normal braking at slower speeds, all seems ok.
    BTW is it an s3 or an a3? MOre common on A3s and golf 4s.
    djb83's Avatar
    redline responsibly
    Sep 2009
    68
    well i have found my problem the fecking power steering rack has failed on me so thats another s3 off the road for now
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    this sounds more like it. thankyou, ill get it checked out. its an A3 BTW. dont suppose you got any pics of what mount it is do you?
    cheers
    Apr 2004
    12,511
    You are unlikely to have the broken bolt due to the engine having been changed last year anyway, we had the lot out, so corrosion and fretting is unlikely
    Feb 2004
    2,036
    No, mine broke after the gearbox had been taken out and put back in for a clutch job. It was a biyatch to undo, and probly weakened it, then when done back up with the impact gun, it started to make the clunk. Took a while to find it, and we ended up having to drill the gbox flange right through and fit and nut on the end of a longer bolt.
    Worth a check as the symtoms were exactly as described.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    think i need to take a drive to the garage of the welshman! lol
