Volks AutosChris Nott
    beachbuggy's Avatar
    Surrey
    1,727
    A3 1.8T turbo Removal
    Is it possible to remove the turbo up through the bonnet, or do I need to get underneath the car to do this?
    any advice would be great.
    Thank you
    Oct 2008
    188
    underneath
    Oct 2009
    86
    did mine fron top, just remove exhaust manifold, undo the 4 bolts on the flange, oil and water pipes and the supporting bracket bolt lift out from the top, thats the way i did mine, took me bout 3 hours os so in total to take 1 out and put new one on
    13.8 santapod gti fest 2010 class g 1st place winner. A3 1.8 20vt 180 quattro, Revo stage 2.5 map,[/B] Forge tip, forge cold side, Forge splitter valve, Carbonio cold intake with aem filter,decat pipe, 2.5inch exhaust, k03s turbo with forge actuator, revs fmc with forge houses, j n75 valve, 4 bar fuel reg, hid's, 17" tt alloys t1r
    beachbuggy's Avatar
    Surrey
    1,727
    Brilliant, thank you. that's exactly what I was hoping someone would say.
    Figured it could be got out via the top but just wanted confirmation before I do it.
