Sky InsuranceBadger5
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Over run water pump not working
    Just got back from my mates got out of the car and notice the pump is running when i got out of the car. Now i took it into audi to have the stat changed so im wondering if there was a plug that they have taken off while chsnging the stat. I also wonder if this is half the reason why my turbo has started to fail.
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    It might sound very strange ste but when you look at the after run pump there are 2 square holes, spray wd40 inside these holes. Mine has been on its way out since i bought the car nearly 4yrs ago, i think it tends to go dry inside. Once i've sprayed some wd inside it gives it some life until it goes dry again.
    The after run pump is there cool the turbo down nice n slowly so if your booting it home then simply turning your car off it won't be helping the turbo at all, especially with the weather being colder.
    Give it a spray and see if it comes back to life
    Nov 2008
    Leicester
    1,246
    Ok i will give this a try Thanks
    Ive been Badger 5'd
    Sep 2009
    Essex
    2,366
    not tempted to put some oil in there. itll last longer. WD is a water displacer primarily so wont last long
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Matt82 View Post
    A bit of 3 in 1.....
    Homer Simpson
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    3 in 1 and oil is all good, i've just got into the habit of squirting a bit of wd everytime i clean it
