EM TuningMonster Motorsport
Results 1 to 10 of 10
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Tips for colouring in climate control buttons?
    Hi all.
    As i was getting quite anakl with replacing worn switchs/ buttons in my s3:
    * Ive sourced a new headunit with no worn buttons.
    * Fitted a new headlight switch with no wear.
    *Fitted a new gearknob with new scratches.
    However, the fan speed button of the climate control is still worn, however i dont fancy replacing the unit?.
    Has anyone coloured theres in? paint/ sharpie/ permanent marker?.
    Can you replace the buttons/ do they pop off?
    Callum
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    I would be interested to know this as I am about to replace all the buttons you have mentioned. Would you mind me PMing you about prices for headlight/radio button replacement?
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    EJD09... Ebay lol, i upgraded to a concert II for the radio so still have some good buttons on my chorus if you require.
    Cost me just over 200 for all of the above i think.
    JD09's Avatar
    Dec 2009
    3,078
    Great to hear, just phoned Audi and been quoted 86inc VAT for the light switch. I'll PM you now about the buttons, many thanks.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    you cant get replacement buttons unless you buy the unit whole, or find someone with a set they removed & have spare. I ve used touch up paint in the pas (matt black)
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    JD09's Avatar
    Dec 2009
    3,078
    Quote Originally Posted by mattyboy199 View Post
    Yes I believe so. Shame, because it is clearly something that happens to most S3s. You can actually replace the bottons when you have spare buttons, but like you say Matt, you have to buy another unit first. Could then just sell the second unit on again/your old one.
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    Alternatively cut up some tape in the shape of the worn button signs and apply permanent marker to the whole button then remove the tape after the marker has dried. Make sure that the buttons are immaculately clean prior to do doing this.
    EDIT: I will post some pictures tomorrow as I have been meaning to do this for a while.
    2001 A3 1.9tdi 130pd (Aka "Osama Bin Diesel") 130bhp 310NM = PMSL
    Done:
    EGR switched off using vag.com. Full no expenses spared service. Refurb Gearbox, new clutch/flywheel.
    In the works:
    Mk II TT Steering wheel (No Airbag), vag.com switchable 3 stage map. Big brake kit. Hybrid turbo.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Ill send you a pic over the weekend JD, when i get my car back.
    That sounds like a good plan 9099, stick some pics up when youve done it, think im going to use a sharpie as a temporary measure.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,641
    hope the tape doesn't pull more of it off
    lloydsta101's Avatar
    Bristol
    134
    I've found that using permanent marker to try and touch things up before has just made it look worse, as most black marker pens seem to dry more of a purple type colour. It’s worth a go though I suppose if there’s no other fix.
    Current: 2007 Audi A3 2.0 TDI (Black)
    Previous: 2000 Audi S3 (Silver)
    Previous: 2003 VW Golf R32 (Blue)
