EM TuningJMB Retrofits
Results 1 to 13 of 13
    Aug 2009
    Gosport, Hants
    367
    Interior door handle, pull twice to open when locked - not working?!
    As per the title, when trying this with my drivers door handle, I have to pull the handle about 6 times before the door will unlock. The passenger side is fine. Has anyone else had this same problem and is it something that can be fixed by taking the door lock apart and making some adjustment, or is it a replacement lock job.
    2003 Dolphin Grey S3, with a few mods....
    Terrier QTS's Avatar
    Jan 2007
    Leek, Staffordshire
    42
    I had this, turned out to be the cable inside the door. For the cost of it I had a new one fitted.
    2001 A3 TQS - Custom Code Phase 1 - Silicone TIP- Supersport Springs, Shocks and Top Mounts - Powerflexed front end - HIDs - 18" TTV6's **FOR SALE**
    Aug 2009
    Gosport, Hants
    367
    Ah, ok. Maybe not too bad then. I'm assuming yours didn't work at all though, or was it the same as mine, and worked after about 6 pulls?
    Khufu's Avatar
    West coast of Scotland
    5,693
    my old A3 did that, it was the plastic clip the metal rod from the interior handle goes into had broken. In one position it was fine but as it rotated round it went to the broken bit and either popped out or left it in a position where pulling the handle didnt put the latch at the door enough to open it.
    Jan 2007
    Leek, Staffordshire
    42
    It started with needing two or three pulls, then went so far out that it didn't disengage the lock at all (I had to do a combat style crawl across to the other side of the car to get out!).
    Aug 2009
    Gosport, Hants
    367
    Ok, cheers guys. Will have to take the door card off at some point and have a look. It works fine when the door is unlocked which is what made me think it was the lock mechanism itself. Sounds like it shouldn't be too difficult to fix.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    mine does it once every now and again.....didnt think anyone on here would know, cheers for raising it Ollie
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Just out of interest, sure people do know this but I'm new
    If you use the VAG Com cable to change the coding (so the doors lock at 15kph), when you stop, turn off the ignition and remove the key, the doors unlock automatically to save the double pull unlock
    Sure you did know this, but hey ho!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    i didnt know about that...thanks fella, so VAG com can make my car lock after 15kph?
    although mine does the double pull on unlocking from the outside, unlocking via the way you suggest wont cure the problem as the car is still essentially unlocking as it would on any other occasion
    Jul 2007
    Wiltshire
    210
    I have the same problem, two or three pulls and the lil sticky up knob thing doesnt move enough, quick press of the unlock button does the trick
    JD09 wont those without a turbo timer be cringing at that idea
    2006-7 Audi S3- 99...Sold
    Honda CBR600RR...Sold
    2009-10 Audi S3 01...Sold
    Suzuki GSX-R 1000 + Suzuki RM-Z450.... KEEPING
    2011 Wants another S3...........
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    Quote Originally Posted by JD09 View Post
    Sorry Pete but I did this myself Via Vagcom. If you can sweet talk someone in your area to letting you borrow vagcom, I can tell you how to turn the auto-lock off
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by Andy_S3 View Post
    Hi Andy, it's not a problem to be honest. Most of the time I take the keys out before I get out anyway, and on the odd occasion I get out and leave the engine running, all I do is press the unlock button on the door. I actually like the auto lock function so will leave it as it is. It's just if I know something's wrong, I like to fix it, even if it's not really affecting me, lol.
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by 1animal1 View Post
    It can chap, I am based in Cheshire and more than happy to lend you the cable/software to do it. Really is easy
    Quote Originally Posted by tankie2ndrtr View Post
    Ha, very true, you didn't hear that from me
    Again, based in Cheshire if anyone wants it doing
