Sky InsuranceChris Nott
Results 1 to 18 of 18
    Hissing sound when accelerating
    Hi
    This question may have been answered before, as found some threads concerning it on the a4 forum but nothing on the a3 forum.
    Just bought a 2001 audi a3 1.9Tdi and have noticed when accelerating it makes a hissing sound. This is audible when you have the window down. It seems to happens at low rpm (about 1500-2500), it does not seem to happen when idling or when just revving the engine. Is it meant to make this noise?
    Any help would be appreciated. Thanks
    sulaiman's Avatar
    Jun 2006
    London
    283
    Sounds like the turbo boosting which you should be very happy of. lol
    A3 TDI Sport
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    I know this sound, i had it on mine, it sounds like air escaping. Do the normal checks on all boost pipes etc - I could never find mine
    kitpayne's Avatar
    Sep 2009
    Warminster, Wiltshire
    128
    I had a 1.9tdi passat which made the same noise. it ended up being a straight piece of rubber pipe near the turbo somewhere. not sure which pipe though!!
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    I get that on mine all the time presume just the turbo, since i have owned thr car its made that hissing noise
    Apr 2010
    well i don't know about anyone but i like this hissing sound :P
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    It's got boost leak written all over it.....
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Oct 2009
    51
    Are you sure it's not just the turbo sucky noise :D
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    That's not really a hiss though, more of a whine....
    Bottom line here is that the facts are a bit sparse!
    Homer Simpson
    Chugger
    North Devon
    2,716
    any major leak will be quite obvious on performance and MPG.
    Boost leaks aare a *******s fiind, just a massive process of elimination. I took mine for a smoke test and they found a little leak, still managed to find another leak afterward.
    57 A3 2.0 TDI Sportback (140)
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Tell me about it, I'm still hunting them down at the moment, after fitting the intercooler 2 months ago!
    Homer Simpson
    Jul 2010
    Hi I have an Audi 1.9tdi 05 driving it the other day heard a slight pop and then the turbo has a loud whining/hissing noise , when I took of the wastegate acuator pipe (vacume) the noise stopped but lack of turbo power when I put the pipe back on I had full turbo power but the whining turbo spinning noise like the wastegate is constantly open , could this be the N75 Solinoid valve or an air leak somewhere I dont think the turbo is at fault as it is not rumbling or rattleling or like a bearing whine just the spinning noise of the turbo ?
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    Mine does the same :-s
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
    Jul 2010
    Hi
    Just got an A4 1.9 tdi 98 s plate and i too have this bloody anoying high pitched whining noise, and when I remove the small pipe from the vacuum unit it stops, anybody replaced this N75 valve there talking about and did it stop the noise? I have checked the turbo fan and there doesn't seem to be any free play or looseness there
    Jul 2010
    anybody have any idea what this problem is ?
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Whats the smoke test??...
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
    shanejess
    if your tyre is now flat it was a puncture nothing to worry about.
    Jul 2010
    Took my A4 to an Audi mechanic yesterday and he says it's normal turbo noise,, well pleased as I thought major expense on the way
