Results 1 to 12 of 12
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Heater Blower quick fix guide and removal
    As there seems to be a lot of people having problems with their heater fan I thought I'd write a guide on how to "quick fix" it, also on how to completely remove the fan.
    Tools required:
    T25 torx bit
    Philips screw driver
    Wire cutters/strippers
    Wire crimper
    Female spade connectors
    Heat shrink or electrical tape
    Cup of tea to keep warm
    First you will need to unclip the side panel on the passenger side (like the fuse box cover). Then undo the 4 torx screws (red arrows) and unclip the glove box light wiring plug (blue arrow).
    Then unscrew the torx screw as pictured below.
    Then there's 3 inside the top of the glove box.
    You may need to support the glove box when undoing the last few screws so it doesn't fall on you.
    Before you take the glove box completely out, there is a clip on the back holding the wire in place, pull the wire out and the glove box can now be removed.
    You will now be able to see the fan and it's wiring plug circled in the photo below
    In most cases you will be able to wriggle this plug and the fan will come on, you can do a few things from this stage. You can either wriggle it to a position so the fan works and tape it in place (but you will most likely have to do this all again in a few weeks) or you can do what I'm about to show you or you can do what Kjc300 done and take the fan apart and resolder the connectors.
    I couldn't see how to take the fan apart easily so I cut the wires and put different spade connectors on.
    The problem with the fan is the spade connectors inside the fan pictured below.
    I found that by pushing the bottom spade connector (the left one in the picture above) down a bit while the wires were attached the fan came on so I wedged another spade connector in the hole to keep it pushed down (I know, a bit of a bodge but it works and saves having to strip the fan or spend 70+ on a new one)
    The following shows how to remove the fan if doing the above doesn't work or you want to go straight to the resoldering option or new fan.
    Unplug the fan wiring connector then pull the wires out of the clip at the bottom of the fan and undo the 3 screws holding the cover on the fan with a philips screw driver.
    There is a plastic type screw underneath the unit which just holds the foam in place, it has a slot for a screw driver but it can be undone by hand.
    When you pull the foam to the side you will see two gold screws holding the bottom of the fan casing on, undo these with a philips screw driver.
    Once undone the panel can be removed and the fan will now slide down and out.
    Here's a pic of the numbers on the side of the fan.
    Hope this helps! Good luck n don't forget to drink your tea before it gets cold.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    How do you get on with that MBC dude? You using it for boost control or to limit boost spiking?
    Completely unrelated to the post I agree.... This post is one for the memory banks!!
    Homer Simpson
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Yeh using it for boost control, running 1.2bar now. Haven't had one problem with it, not bad for 15.
    PS3: Broady_11
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Lemon S3 View Post
    No, indeed not! I like the R Spec ones, I had one on my AGU A3. Not getting any problems with engine management kicking up a stink about it?
    Homer Simpson
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    498
    excelent thread mate, im going to strip it all apart gain this weekend and see if i can finally sort it.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Nice write up matey. I've not heard of any fan problems, whats the common problem?
    Also is this the best way to get behind the dash when fitting a boost guage?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Yeh the r-spec ones look pretty smart but this one does the job. No problems with engine management, only when I first fitted it and was finding out the amount of turns to give me standard boost then turn it up a bit but went a bit far n it went into 'limp' mode.
    Quote Originally Posted by Westle View Post
    Cheers dude.
    A lot of people's fans have been failing, going really slow, making horrible noises, intermittently working or not working at all. It's the connectors inside the fan which is the problem, think it has something to do with the cold.
    I fed all the pipes and wires in through the passenger side of the bulkhead, didn't remove the glove box though. Fed them through a gromet and you can get your arm behind the dash to get to them. i did remove the dash under the steering wheel though to wire everything up.
    PS3: Broady_11
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Wouldn't be my first choice Westle, BUT I guess it depends on where you're running it to. If you want it driver's side, you can punch through where the main loom runs down into the cabin, under the scuttle driver's side. There is even a nice grommet for you to use!
    See this thread http://www.audi-sport.net/vb/showthr...0boost%20gauge
    Homer Simpson
    millsy75's Avatar
    Dec 2012
    198
    Cheers dude.
    Hello, thanks for the guide. My fan is making a horrible grumbling noise that increases with the speed of the fan. Do you think this could be the fault? I thought I may need a new fan due to bearings knackered?
    Audi want £170 for the part lol
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by millsy75 View Post
    Yeah it sounds like it could be the same problem. Have a go at fixing it n save yourself £170.
    PS3: Broady_11
    millsy75's Avatar
    Dec 2012
    198
    Yeah it sounds like it could be the same prohave a go at fixing it n save yourself £170.
    Thanks mate I will have a go at pushing the spade connectors in and hopefully it works :-)
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    Another thread bump here.
    Found this guide whilst searching last night, I had already bought a new motor thinking it was that, but on inspection, it was just the wiring as you suggested.
    Cut off the factory plug and crimped on 2 new spades, pushed them firmly home, and it jumped back into life
    Thanks very much!
