Chris NottSky Insurance
Results 1 to 13 of 13
Thread: De-Cat
    big_mo's Avatar
    MOSES
    Nov 2007
    A great place called high wycombe, bucks
    137
    De-Cat
    Need some help before my money bruns a hole in my pocket.
    Have a 2001 1.8t AUM (150) also with a stage 1 cc remap and i want to take the CAT out. All i want to know is.........
    1 is it werth it?
    2 I have a CAT back system by taking that out will it make it any louder?
    3 will it bring any fault codes up?
    4 How meany Lamba probes do i have?
    1.8t,AUM,Ming blue,Forge TIP,Forge silicone turbo hoses,BMC CDA,Forge 007p,Neuspeed short shift gearlink,powerflow hidden cat back,miltek downpipe,R8 oil cap,HIDs,Custom Code stage 1,de badged,de wipered,FKcoilovers
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by big_mo View Post
    1 is it werth it?
    The cat is pretty restrictive as well as the downpipe so by removing it you allow the gases to flow better. It will be louder, it might bring fault codes up, you can get remaps to take the lambda sensor out but you've already had one done. I'm pretty sure you only have one sensor.
    I'm going to get mine decatted when I get my turbo back system done but have it so I can bolt the cat back in for MOT time.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    big_mo's Avatar
    MOSES
    Nov 2007
    137
    Ok so because i have a remap already will i have to goand get it done again?
    So if i do have the one than it would be before the CAT then it should be good....
    Yeah thats what im going to do just in case Mr MOT man fails me
    DionBullock's Avatar
    Dion
    North Wales
    68
    ive just de-catted mine, (aum 150) with a full stainless system,
    it is pretty loud, and the lovely little popps you get now and again when changing down a gear are quite entertaining (whether theyre doing any damage to the engine im not sure?)
    to get the most out of it, ur better off going for a custom stage 2 map, i think CC do a deal if u already have stage 1 map im sure??
    Stage 2 map is next on my list
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    i was under the impression the S3/A3 CAT's weren't that restrictive..... it isnt a common mod for that very reason.....
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Feb 2008
    2,817
    I thought the cats weren't that restrictive. Results are in the stickies I think.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Dec 2009
    13
    well am lookin for a cat back exhaust and maybe a dwn pipe, should i bother with thede cat then???
    Dion
    North Wales
    68
    ive felt the diffrence between having my A3 aum 150 catted & de-catted,
    its not the noise making it sound faster either, i have my own little "test route" (dont laugh!) and compare the before and afters of what ive done to the audi,
    im not claiming or saying it gives it alot more bhp or torque because i havnt had the chance to do a RR printout, but from experience, its made a diffrence to my AUM audi 150bhp
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,899
    Dec 2009
    13
    forgot to mention i have an s3 210 bhp wi a remap!! am guessin the down pipe makes a diff though, a just want a bit more noise, cars way to quiet fur me
    Dion
    North Wales
    68
    hmm... mine only had the 1 cat to begin with....
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,365
    you have two lambda sensors. 1 pre cat and 1 post cat.
    If you remove the cat, you WILL get an engine management light, as it'll think the cat has failled.
    SOME companies can map out the post cat lambda, but most can't/dont.
    The standard cat is not a huge restriction at all, but the standard downpipe on the A3 is a MASSIVE restriction. Ditch it and you'll gain loads of spool up, and more top end as well.
    big_mo's Avatar
    MOSES
    Nov 2007
    137
    Well like i said only got an A3 so i have a single CAT
    Prawn i can have a downpipe made up so shall i leave the cat in and just get the down pipe made up?
