JMB RetrofitsAH Fabrications
    Apr 2009
    Preston
    245
    5-6k service due for my 8L
    My 8L is a 2002 plate. 61k. Full A.S.H. with reciepts.
    Other then the below...
    Sparks plugs *x4 (check) Which 1's would be best?
    Engine Oil *5ltrs (Check) 0-30w Fully synthetic?
    Oil Filter (OEM)
    Fuel filter??
    Diff oil??
    Anything else, please advise ASAP.
    Much appr.
    Joe
    putang's Avatar
    Oct 2007
    154
    air filter
    52 plate black s3,Star performance remap, 18" bbs lm reps, adjustable tie bars, bilstein b8s, eibach springs, forge 007p, panel filter, covered in rg55
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Pollen filter
    Sump plug
    Think the fuel filter would be alright for the milage
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    Apr 2009
    Preston
    245
    Its had a air filter (pipercross panel) in the last 6 months.
    Pollen filter- Easy to fit? How much?
    Sump plug- How much? 5?
    Cheers chaps
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Got Haldex (S3 or 1.8T Quattro)?
    Haldex oil and filter.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    If it's not been done already then the cambelt is a definate "MUST DO" at that mileage, and when doing the cambelt you should replace the waterpump at the same time as it will save a lot of headaches later. Hope this helps
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
