EM TuningVolks Autos
    imported_Rooney
    Alloy Wheel Bolts?
    If I were to buy some Original Audi TT 18" RS4 look-alikes, Will the bolts from My standard 17" Avus Wheels fit them?
    or
    do i need to purcase new bolts to fit the 18"?
    Help please!
    Stepho's Avatar
    Feb 2004
    Strathclyde
    446
    Re: Alloy Wheel Bolts?
    If you are purchasing aftermarket replica RSTT's they should come with new wheel bolts.
    imported_Rooney
    No they are originals off an audi TT, only single drilled not multi drilled like most replicas.
    Stepho's Avatar
    Feb 2004
    Strathclyde
    446
    I've had two sets of replicas and niether were cross-drilled, but the answer to your origional question is the bolts from your Avus style alloys should fit no problem. A way to check however would be to remove one off wheel bolt and pop it in your RSTT wheel through the hole and pull the threaded end at the back of the wheel you should be able to feel if it is seated properly. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2003
    Bekshire S.E.
    33
    just got some original RS TT 18" wheels to replace my 17" Avus and used original bolts with no problem. [img]/ubbthreads/images/graemlins/groovy.gif[/img]
