    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    Aftermarket Actuator MORE BOOST MORE POWER?
    http://www.forgemotorsport.co.uk/con...duct=FMACVAG01
    the blurb-
    While Forge Motorsport is happy to supply you with an actuator capable of holding boost beyond that of your factory unit we are in no way capable of knowing nor suggesting that your vehicle's engine or related systems are capable of supporting or surviving the stresses of such elevated boost pressure.
    so would this give more power? or would it just stress the engine for no point?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Depends on the preload and the spring used... higher preload or stiffer spring will make it harder for the N75 to control the boost properly and will effectively give you more boost... this however isn't recommended as it can and probably will lead to a nasty boost spike while the N75 tries to reign in the boost (made more difficult by the stiffer spring etc of the actuator) resulting in bent rods and other such catastrophic engine failures...
    I run a 1 bar actuator on my GT3071r, K04's run a 0.5bar actuator.... I also run over 1.5bar boost pressure (soon to been 1.8bar) and the 1bar actuator is better suited to this kind of boost pressure. Higher boost will generate higher exhaust pressure and this has the affect of forcing the wastegate open if the acutator isn't strong enough or the preload is set wrong... I had this issue with mine and adjusted the preload a bit which gives me the ability to run 1.8bar and hold it....
    Forge actuators are good though, Ibiza boys on SCN use them a lot.... not something you want to undertake unless you know what you are doing really...
    <tuffty/>
    flat out if in doubt
    stoke on trent
    149
    so how do you set them up.is it just a case of taking the old unit off and making the bars the same length so the waste gate is open the same
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    something i deffinitely wont be attempting by myself then. so are their reasonable safe gains to be had if set up by someone who knows what they're talking about? seems like quite a cheap`part for more possible power
    RIP S3dave
    May 2004
    nr Glos
    7,156
    actuator being stiffer will effect the ecu's boost control.
    you would fit a stiffer actuator spring to hold the wasetgate shut if its being "pushed" open by manifold pressure.... BUT, you risk the ecu dropping into limp mode when it see's a different actual to request, and flagging a positive deviation code
    higher actuator pressure is also mor elikely more spikey boost, hence torque delivery
    too much, and say hello to mr rod
    ecu asks for its boost.. its electronic controlled.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
