Results 1 to 16 of 16
    tim-igoe's Avatar
    Cheshire
    25
    Uneven Rev problem
    Recently got an A3 1.6 sport 2002. When i bought it i noticed there was a slight uneven tickover, i didnt think anything of it, just thought it needed a good service.
    However I have now noticed that when the car gets warm and i pull up to a set of traffic lights for instance, the revs go up and down between 1000 and 2000 for about five seconds before they settle down.
    I went to a local audi specialist yesterday and he said that because the throttle is electric instead of cable then the throttle body gets dirty and it just needs a clean. Just wonderin if anyone could give me some advice on this.
    Regards
    Tim
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Yep, dirty throttle body.
    Just take the intake hose off and spray some carb cleaner in there, hold a rag under it for when all the cruddy black cleaner pours back out though!.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    tim-igoe's Avatar
    Cheshire
    25
    cheers mate thanks alot, just wonderin which is the intake hose, is it the large one?
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    Big rubber one at the front left of of the engine bay (as you look at it). Connects to the intake manifold by the throttle...
    Cheap and Reliable is not Fast. Cheap and Fast is not Reliable. Fast and Reliable is not Cheap!
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Someone correct me if i'm wrong but if you catch the butterfly valve and move it doesnt it need to realigned with vagcom?
    S3KO4's Avatar
    Aug 2009
    London
    850
    It does need realignment, but you can also remove the battery for a few minutes and it will do the same thing.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    tim-igoe's Avatar
    Cheshire
    25
    now im confused , can somebody just run me through the steps of what to do, this butterfly valve thing has opened a new can of worms.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    As said above, when you look at the engine bay you will see a rubber hose come up on the front left of the engine bay. Pop that off and spray the cleaner in.
    My butterfly was fine afterwards so its nothing to worry about
    tim-igoe's Avatar
    Cheshire
    25
    i undersand that part mate, just finding it hard to find which hose it is, when i look into the engine bay there is numerous amounts of hoses. I cleaned the hose out today which goes from the air filter as i thought this was the right one. Turns out it isnt Just need a bit more detail to distinguish which one it is, ie. how big is it and where does it go from and to.
    Very much appreciated mate
    Tim
    It's all in bits
    Apr 2006
    Bristol
    219
    This is the hose on an S3, but I'd guess the 1.6 can't be much different...
    You might find this thread helpful too
    tim-igoe's Avatar
    Cheshire
    25
    I presumed that it was the metal part which the air intake pipe connects to. I have cleaned that pipe out but still no difference. This is the picture without the cover on. I appreciate your help guys.
    It's all in bits
    Apr 2006
    Bristol
    219
    Sorry, it quite different isn't it!
    The butterfly valve should be in the bit that is arrowed, so I think you were in the right place.
    tim-igoe's Avatar
    Cheshire
    25
    yes it is mate, now is it the thick pipe to the right of it cus thats all i have cleaned and to be honest there wasn't much dirt inside it. Or do i clean inside the throttle housing where the butterfly valve is. Cheers Tim.
    tim-igoe's Avatar
    Cheshire
    25
    any ideas??
    It's all in bits
    Apr 2006
    Bristol
    219
    Quote Originally Posted by tim-igoe View Post
    Yes. My understanding is that really need to do both sides so you would have to remove throttle body housing completely.
    tim-igoe's Avatar
    Cheshire
    25
    cheers mate, could probably do with a haynes manual now!
