Temp sensor
zeeeebo
Lifes one big laugh
worthing
has anyone got a close up pic of how to change a temp sensor?
anyone got any links as search is down! i got to try and fit this tomorrow and dont know where it actually is or how to chnage it! just to complicate things i have 2 sensors as the garage didnt know which one it was!
Its easy mate, nothing to worry about.
Do it when the car is cold for minimal coolant loss.
Take the engine cover off and look down to the right of the engine between the block and the airbox. You'll see the coolant hose running towards the back of the engine.
The sensor is on there, you'll see the plug on the sensor so just unplug that (test fit the new ones you have to decide which one fits)
The sensor itself is held in with a plastic clip, prise that off with a screw driver (have the new sensor ready)
Pull the old one out and put the new one in, make sure the rubber O ring is on it.
Insert plastic clip back in and plug the wire back onto it.
Top up coolant as required and jobs a good one.
Takes less than 10 minutes :)
ok fitted the new temp sensor but the vag is still saying there is a temp sensor problem?!
also anyone fitting a temp sensor make sure you have a spare plastic clip!
Sorry to hijack your thread,
Can someone please let me know the part number/code for a temp sensor, 2001 AMK
7
611
6
832
20
2K
SDO
15
