Monster MotorsportBadger5
Results 1 to 13 of 13
    Apr 2004
    Hampshire, UK
    93
    Brake pedal switch - fitting instructions ??
    Does anyone have a guide or any tips regarding the fitting of a brake pedal switch, any tips on how to remove the piece of trim under the dash to give better access would be useful, car is a 2000 (face lift) A3 1.8T.
    A3 1.8t, Facelift, 5Door, Standard.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    I have changed my brake switch after it decided to break off overnight, leaving the brake lights on all night and draining my battery!
    It's a simple case of removing the lower dash cover, unplugging the connector on the switch and twisting the switch anticlockwise to remove it. Refit new one (by simply inserting into the vacant hole and twist clockwise to lock it into place). I found that the new switch fitted in a slightly different position to the old one and it is easier to put the wiring connector on first and then locking the switch into place if that helps.
    Imteyaz.
    Apr 2004
    Hampshire, UK
    93
    Thanks Imteyaz, is the lower dash cover easy to remove, are the fixings easily visible ?
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    IIRC there are some torx screws below the steering wheel and some behind the panel where the fuses hide.
    Cheap and Reliable is not Fast. Cheap and Fast is not Reliable. Fast and Reliable is not Cheap!
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Sign up on VAGCAT and have a look at this link: http://www.vagcat.com/epc/cat/au/A3/...09/56/2577063/
    It shows you where most of the screws are, remove them, remove headlight switch by (I think) pressing the switch in and twisting it anticlockwise, then pulling out towards you, and voila (he says...).
    Remove the lower trim, the trim panel is clipped in place at the top but a firm pull will get it off. It's not too difficult, I recommend getting a Haynes manual if in doubt. I used the local library (first time in over 20 years...) to get hold of one and it came in handy for the simple stuff like removing panels etc. HTH,
    Imteyaz.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    I managed to contort my arm/hand enough to get at it with the lower panel in place... few nice cuts on my arm afterwards though lol.
    Ross_S4
    Aug 2009
    Dundee
    718
    open your door, put driver seat right back, feet on the floor and your back on the sill, head down by the clutch pedal looking up. bingo.
    Keeno's Avatar
    Apr 2009
    West Sussex
    695
    Quote Originally Posted by rossbrownlee View Post
    Doesn't work. Only way to do it is to remove the lower dash. I don't remeber having to remove any of the dash surrounding the headlight switch though...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,589
    You must be a midget.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Quote Originally Posted by Keeno View Post
    The lower dash trim that you need to remove has the headlight switch fittied to it, removing the headlight switch eliminates the risk of yanking out the cabling for the headlight switch accidently when the trim is removed...
    Imteyaz.
    Apr 2004
    Hampshire, UK
    93
    Cheers for your help guys, hopefully try and fit the switch tonight, I'll let you no how I get on and fingers crossed it will solve the ESP light problem.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    when you replace the trim make sure you clip the bottom into the two black guides....most people tend to miss these which results in a bit of flappiness above ya pedals
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Apr 2004
    Hampshire, UK
    93
    Cheers guys, replaced the brake switch and all working again.
