JMB RetrofitsAH Fabrications
    clcollins's Avatar
    Mar 2004
    Lancashire
    276
    How do you fit new springs
    Perhaps I should have asked this before buying them, how do you fit new lowering springs?
    I have bought the Eibach Pro kit, I can't see it being too difficult, just time consuming.
    All help appreciated [img]/ubbthreads/images/graemlins/grin.gif[/img]
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    Re: How do you fit new springs
    remove legsfrom vehicle get a spring compressor and compress spring unbolt top nut and change sspring, refit in reverse order, not forgetting the full 4 wheel alignment required to set up the suspension so car sits right!
    Oct 2003
    South Wales
    2,942
    [ QUOTE ]
    [/ QUOTE ]
    Expect to pay about 80+ to get the 4 wheel allignment done at the stealers! You can get it cheaper but its quite an involved job so I'm told.
    clcollins's Avatar
    Mar 2004
    Lancashire
    276
    [ QUOTE ]
    [/ QUOTE ]
    Bugger, that's more work than I was expecting, spring compressor?, 4 wheel alignment?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Took me the best part of 4 hours to change the springs on my A3... The hardest part was removing the shock/spring unit! Once this is out, you can compress the spring and remove it from the shock VERY easily...takes all of about 2 minutes..same for replacing it. As for putting the shock back in the car, clean off the mating surfaces with WD40 and some fine wet&dry and it slips back in nicely... Not a hard job, just time consuming and a bit fristrating when bits wont come apart!
    Rich
