Get a missus with very small hands! /ubbthreads/images/graemlins/lol.gif
I found the Drivers side lamp a bit easier, open the rear cover and push it back as far as it will go. then squeeze your fingers in. I found looking in through the front of the h/lamp helps to guide me to the correct wires/bulbholder, as you can see it moving when your hand is on it. Pull this out and carefully pull bulb from holder and replace. Getting it all back is a little tricky. Turning the sidelights on a this point helps to guide the new bulb into the hole in the headlamp (again look from front)Then push firmly home. Passenger side is made more awkward by less available space, but I usually manage to pull the bulb out carefully by its wires (I know I shouldn't, but I'm not moving the battery for a poxy sidelight) Again replace the bulb. At this point I just manage to push it all back with the end of my finger, as whole hand will not fit in space. Hurts a bit though, but worth it in the end. Should take about 10 mins all in.
Good luck
Chris. /ubbthreads/images/graemlins/beerchug.gif
