AH FabricationsChris Nott
Results 1 to 22 of 22
    02audis3's Avatar
    Aug 2009
    133
    Lowered without spacers
    Cars lowered with dampers all round, Is it normal for the rear wheels to sit out at the bottom and in more at the top if you know what i mean
    ie. left wheel like /
    and right like \ obv not as much but you get what i mean.
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Yeah its called negative camber. Always happens when you lower a car, nothing to worry about unless its excessive.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Sep 2009
    worcester
    1,097
    how much did you lower it by?
    you may need a camber correction kit / 4 wheel alignment
    02audis3's Avatar
    Aug 2009
    133
    Thanks, think its 40mm, Its not to bad just notice it because i dont have spacers and my wheels sit away in need to get spacers asap and new wheels only 17's.
    will look into the camber correction kit / 4 wheel alignment when i get 18's on with spacers.
    thanks again
    May 2006
    Surrey
    175
    Unfortunately this is why it costs so much to lower S3s as the rear tie bars are not adjustable to if you lower your quite a bit you won't be able to correct that negative camber which will eat its way through your tires, the expensive part is buying adjustable rear tie bars which cost around 250. I am in the same position as you running excessive negative camber and need to buy the tie bars.
    Audi S3 2001. Black on Black. OE Sat Nav/Freeview. Bose. 18" Audi/BBS Splits. 10+16mm Spacers. KW Coilovers. Forge DV,tip and intercooler pipes. KnN Panel Filter. Oh and the essential Re-map. GONE
    02audis3's Avatar
    Aug 2009
    133
    were do you get this camber correction kit from thanks
    02audis3's Avatar
    Aug 2009
    133
    so buy tie bars and camber kit to sort this?
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Take a photo if you can mate and post it on here because I don't think the correction will be necessary as I've got 18s with 20mm spacers and 35mm lowering springs and it's fine, you want some negative camber.
    PS3: Broady_11
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Negative camber, whilst eating through your tires, normally makes the car stick to the road like sh*t to a blanket!! I used to have a motor in days of old that was slammed, so much so that it used to eat the inside edge to the wear bars and have 5 mm of tread on the outside edge....
    Get somewhere to swap the back tires side to side and you get full running out of them!!
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    02audis3's Avatar
    Aug 2009
    133
    Will get pics up asap , mates got car for week i have jeep ,
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by 02audis3 View Post
    Here: http://www.dpmperformance.co.uk/tie-...ab01777ae3a502
    Few here aswell: http://www.awesome-gti.co.uk/section...ec=388&xPage=1
    Probably few other places aswell, these are just the ones I've seen.
    2003 Dolphin Grey S3, with a few mods....
    Dec 2009
    Warrington
    27
    http://www.audi-sport.net/vb/showthr...d-Set-up-Guide
    I was asking the same questions a couple of week ago...
    Reversed 007 = Turbo Qweef
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    As mentioned, rear adjustable tie bars will cure this problem.
    The Forge bars come with a life time warranty.
    http://www.dpmperformance.co.uk/forg...199-p-772.html
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    How low can you go before you require the tie bars?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by Westle View Post
    I think its 40mm.
    PS3: Broady_11
    mattyboy199's Avatar
    Nov 2005
    UK
    1,678
    i noticed this negative camber when i once loaded my boot & back seats full of fixings i needed to move for work, almost looked likes the wheels were gonna pop off !
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Westy's Avatar
    Dec 2008
    17,158
    Quote Originally Posted by Lemon S3 View Post
    I think its 40mm.
    So if I bought coilovers and only went 35mm lower I could get away with the standard tie bars?
    S3 Build Thread
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Ive lowered mine by 35mm n its fine, so yeh go for it.
    PS3: Broady_11
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    I would advise changing the tie even lowering by 25mm tbh... there are tons of threads on here but as the search is currently disabled then its a bit difficult to point in the direction of them
    Check out Ess_Three's performance guides in the stickies, he covers suspension thoroughly.
    http://www.audi-sport.net/vb/showthr...esting-Day-Pt9
    S3's have about 1.5 degrees negative camber as std, lowering increases this and lowering at much over 25mm increases this alot... while negative camber is generally a good thing on the front, it will make the back end a bit skittish, add strain to the OEM tie bars which have a habit of snapping and nuke the inside edge of tyres.
    Awesome GTI were doing some tie bars quite cheap IIRC, get um bought and get the car 4 wheel aligned. Transforms the S3's handling IMO...
    <tuffty/>
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    As said above, no matter what drop on the S3 it's always best to get adjustable tie bars.
    It's not just the negative camber but it's also the strain that lowering puts on the standard bars.
    DPM Performance
    T: 01207 561606
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    My car, on standard suspension with 15mm spacers, has a fair amount of negative camber at the rear (visually very obvious and certainly more than 1.5 degrees).
    Could this have happened if the original suspension is knackered? I'm sure I heard a weird spring-twanging noise recently while reversing off my driveway and the car is acting a little skittish...
    Could I have broken a spring or standard tie bar? I did have a quick look but couldn't see anything obvious.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    Yeah it's a common thing for the springs at the rear to snap at the bottom.
    Water gets in and just sits in the cup that holds the springs and over time just rusts and weakens the bottom pig tail of the spring.
    DPM Performance
    T: 01207 561606
