JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    Fault Code.. Anybody had this before?
    Hello everyone, plugged VAG-Com in today for first time on my car..
    I had this warning..
    Address 01 : Engine
    1 Fault Found:
    00561 - Micture Adaption
    14-10 Adaption Limit (add) Exceeded - Intermittent
    Rediness N/A
    I did a bit of research and got this info.
    Anybody had this error before,
    Does it mean its over or under fueling?
    My car is rather modified, with new turbo, remap, exhaust, decat, hoses etc, and sometimes on the motorway when i accelerate it doesnt seem to grunt as much.
    Anyone think thats this error?
    00561 - Mixture Adaptation
    00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
    Possible Symptoms
    • Engine Jolting
    • Increased Fuel Consumption
    • Poor Idling/Jolting
    • Reduced Boost Pressure
    Possible Causes
    • Mass Air Flow Sensor (G70) faulty
    • Fuel Pressure too Low
    • Leaks in Intake Air System and/or Exhaust System
    • Injector(s) faulty (i.e. coked)
    Possible Solutions
    • Refuel Vehicle
    • Check Fuel System Pressure
    • Check Mass Air Flow Sensor (G70)
    • Check Intake Air System and Exhaust System for Leaks
    • Check Injection Quantity
    • Check Injector(s)
    How can I check the fuel pressure system or the MAF?
    or even the injection quantity?
    Thanks all, Ryan
    Cars:
    Now: Audi TT Project car but looking for An S3 Project.
    Past: Audi A5 3.0 V6 TDI 300BHP 481 lbft
    Past: Audi S3 MTM 345BHP
    Sep 2009
    worcester
    1,097
    you can check the maf easy enough, disconnect it and go for a drive, it it drives better your maf is screwed
    i have no idea about how to check the fuelling side of things, someone will be able to tell you though
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    in that case the Maf is fine, however some mornings the idle does bounce, which i thought was the maff?
    When the mafs disconnected my car is almost back to standard that tiny little 150bhp i used to have..
    Ouch.. my car used to be slowww :P
    Cars:
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,468
    You might want to have a look at the fuel pump too?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    With the engine warm and idling, check what block 032 says... they will be the fuel trim values...
    These should be more or less 0.0% for both...
    <tuffty/>
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Im new to Vag-Com.. How do i do this Tufft?
    Cars:
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    When in the engine control module (01), go to measuring blocks (08), enter 032 in the first group box and click go...
    <tuffty/>
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    At the risk of sounding stupid..
    With the engine on yes?
    haha
    Cars:
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Quote Originally Posted by RyanA31.8T View Post
    haha
    Yes mate...
    <tuffty/>
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    I cannot run anything past 025, as im not registerered, and got very annoyed.. hahaha..
    SO i give up...
    Has anyone got Vagcom in the Bristol Area / North Somerset that could offer me a hand...
    Thanks, Ryan
    Cars:
