alright mate i think you need to put a link in between the two terminals on the connector for the brake pad sensor then tape it up to keep it in place and the connector clean etc.
you could just snip the wires and crimp/solder/choc-block them together, however this means if you or anyone else wants to go back to standard at some point in the future it is much more difficult if at all possible.
In fact if you have not yet chucked the standard pads then cut off the sensor cable close to the pad backplate, twist and solder/crimp the wires together then give it a good leccy tape up to keep it from shorting with anything in the wheel well. This goves you your wire loop complete with connector to plug into the loom.
