AH FabricationsEM Tuning
    Garrity's Avatar
    Jan 2007
    No power to symphony after battery change.
    I don’t know if anyone’s had this problem or any advice on where to look. I replaced the battery yesterday as the cold weather killed my old one. Anyways, everything seems to be working fine apart from my symphony stereo, there appears to be no power going to it at all, even with the headlights on none of the button lights turn on. I’ve check the fuse and that appears fine, I’ve even swapped it with a different fuse of the same rating and still no life. I’m at a bit of a lose where to look next – anyone with any ideas would be greatly appreciated.
    S3 Nogaro Blue - 2001 Facelift, 210bhp
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    There's a fuse behind the head unit which might have blown. This happened in my A4 after I got a new battery.
    Garrity's Avatar
    Jan 2007
    Brilliant, this put my mind at rest a little (was worried it was total gone). Need to remove the headunit to fit my xmas pressie (Dension Gatway 100) so will have a look at the weekend. Cheers.
    Dec 2009
    36
    hi there i had the same sort of prob, and it was the fuse on the unit itslef that had blow.
    changed it and all ok
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    The exact same thing happened to me yeseterday thats a relief!!!
Tags for this Thread
