EM TuningMonster Motorsport
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    Oil level sensor
    Anyone had this? Mine came on briefly last night. Just after a service! He said it was giving an implausible signal on VCDS (a long with brake switch!). I was told to ignore it as to change it will require more new oil!
    Brake light switch i assume is easy to change myself...Like clutch switch?
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
    May 2009
    Brake light switch is a straight forward replacement. There is a good guide here:
    http://forums.vwvortex.com/zerothread?id=1158315
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    The issue with ignoring the faulty oil level sensor to my mind is that the car won't warn you when she's low on oil..... I'd pull the plug off and clean and spray with WD 40 to see if it's just a bad connection. Lots of salt on the raod at the moment, might not of done any good...
    Not to state the obvious, it's just that it would concern me....
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    I get what you're saying. If it wasn't for the fact that the mechanic told me about the problem as i collected it from service then i would be worrying. He said not to worry about it and showed me the VCDS report. It came on then off 4 times on the way home though!
    Funny, in the lasty year of owning it i've never seen the warning, then as soon as its been serviced its been on 6 times!
    Dec 2009
    36
    The Exact same things happened to my car after a service the oil sensor came on randomly, ill check the levels all the time and everythings ok. mechanic said would be a costly to get it changed but he never said anything about more oil needed, he stated its a faulty sensor.
    Mines an a3 tdi on a 2000 if ANY one knows a solution pls let me know
    cheers
    oh yh where is the sensor located on the car i might try have a look at it myself even tho im a novice
    Ross_S4
    Aug 2009
    Dundee
    718
    the sensor is on the bottom of the sump pan. close to where the oil return from the turbo ties in.
    Splitting, cleaning and remaking the connector is a good idea but if it doesn't fix it then personally i would replace it next time you do oil change.
    bit dubious it was no problem then suddenly it is after your service...
    replacing it is an oil change job as it screws onto the bottom of the sump and the sensor part of it pokes through a hole up into the oil.
    replacements here.
