Volks AutosEM Tuning
Results 1 to 20 of 20
    14
    Fitting / replacing a front S3 ARB
    Hi this is a first post and I'm asking for information (but you have to start somewhere) Has anyone any experience of fitting a front anti-roll bar to the S3. The one on the car at the moment is knocking as the plastic sleeves have broken away. The haynes manual says that you can manoeuvre the bar out and replace without having to remove anything, is this correct? And / or has anyone got any advice as I will be doing the job myself.
    Chris
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    I think the job involves removing the lower subframe to gain access/clearance. I could be wrong though.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    From another thread where new arb were being fitted:
    Front...nightmare! Power steering rack off the subframe, balljoints off, ARB drop links dissconnected front subframe completely removed from the car, change the ARB...and get it all back together...not an easy or quick job.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I managed to fit a Whiteline one to my A3 without removing anything.
    A total pig but if you're happy to get a mate to help you manoever it through, I expect it can be done on an S3. I know transfer box may be in the way though which we didn't have to deal with. I haven't looked at mine on the S3 dude to be honest.
    I'd have a look and use your judgement....
    The key thing here is that: If you can get the old one out, you will be able to get the new one in....
    Homer Simpson
    Sep 2009
    worcester
    1,097
    if all the above needs to be removed can it be done on axle stands or is a ramp/lift necessary, i want to give this a bash myself, mainly because i aint got the money to pay someone lol
    i would def try and find another way around it first though, although haynes can sometimes be a bit inaccurate they wouldnt say not to remove anything if they didnt have to
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    You just have to lower Sub frame and stearing rack not remove them. There is a awkward fixing on the passenger side , think its a pipe attached to the subframe with a 10mm nut iirc. Its not too bad a job tbh
    red to red black to black blue to bits
    Sep 2009
    worcester
    1,097
    cool cool, i may have to get a haynes manual/workshop manual to point me in the right direction, never done arbs before
    14
    Thanks for all the replies to this thread, I'll give it a go. So long as the whole subframe does not have to be moved - that was my main worry.
    Chris
    Sep 2009
    worcester
    1,097
    when you get round to doing this mate, let me know how you got on?
    what you had to remove, if anything?
    will be doing this in the next month or so too and would appreciate some info
    14
    Will do, just waiting for the car back from the body shop - they are fixing the roof rail corrosion issue.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    erm, i have it on good authority that you only need to change the bushes...then you wont need to remove the ARB meaning no problems????
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    fran-s3's Avatar
    1,090
    correct my mate did my bushes without removing the arb....
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    the Audi chap that does most of my work said originally that id have to change the whole bar as the plastic part is unchangeable, however there is now a modified bush/holder that negates the need for this....
    14
    Well I have finally replaced the front anti roll bar. To be honest it was a bit of a pig of a job the worst bit was trying to get the clamps that hold the bar on bolted up (because the new rubber bushes need compressing. Here is a quick run through:
    jack up and remove both front wheels
    unbolt the ARB from the connector that attaches to the front strut
    unbolt the ride level sensor on near side
    unbolt the two ARB clamps (10mm) there is a hose clamp attached to the near side
    unbolt the four (13mm) bolts that hold the steering rack to the subframe - losen rack
    unbolt the four bolts that hold the subframe to the underside - while supporting the subframe with a jack
    lower subframe
    ease out the old anti roll bar - this cannot be done with out lowering the subframe
    replece with new ARB and put everything back together
    you may want a selection of longer bolts and clamps to get the ARB clamps back in place as the rubber is hard to compress.
    Just one note the Audi 'fix' for the ARB plastic collars breaking up, is just a new rubber bush with a thinner hole in it. - why they didn't do it that way in the start, I will never know.
    Hope this helps someone
    Chris
    thats me
    Sep 2004
    west yorkshire
    3,762
    Audi just used a std ARB bush I think they are the same bush across the range of arb`s the the bar is sleved to fit the bush. This is probally down to the large tooling costs when producing the bushes compared to the low cost of sleving the ARB.
    As for the bushes a pair of long nose mold grips work a treat to compress the bush then fasten in place
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    the sleeve probably increases the diameter to be the same as a R32 roll bar (23mm)
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    14
    Just one thing to add, it was not posible to just replace the bushes and keep the same anti roll bar. There are collars attached to ARB that I assume keep it in a central location - these on the old ARB had broken off, meaning the bar had the potential to move sideways.
    Chris
    I wish I had had some long nose mole grips but a selection of bolts did the trick.
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    533
    Hi guys,
    I'm thinking of doing this myself, so have brought this thread back to life So, I measured up my front ARB and it is 19mm; therefor I ordered some 19mm bushes from Powerflex. With these, can I get rid of the need for the "plastic collars" and just replace the bushes striaght onto the bar without having to the take the whole ARB out?
    Cheers,
    Aran
    Oct 2012
    Cardiff
    12
    Quote Originally Posted by Squirrelofdoom View Post
    Hi guys,
    Cheers,
    Aran
    Hi Aran,
    How did you get on in the end? Mine had broken too, so today I fitted 20mm bushes, without the plastic collar/housing, all seems ok.
    Can anyone clarify this is ok?
    Gareth
    Feb 2012
    Surrey
    533
    Hi mate,
    I fitted the 19mm ones without the plastic collar. Things seem to be ok so far...I did however install my bushes upside down Still, they've been fine :P
