Volks AutosSky Insurance
Results 1 to 12 of 12
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    A3 driver's door rattling when swung shut.
    As the title says, my drivers door sounds like a bag of broken plates when swung shut.
    The electric window works perfectly, so it is safe to rule that out.
    What could it be?
    Views and opinions welcomed and appreciated.
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    guys... please help. I am going to kent (car is at my aunts atm) tomorrow to sort a few bit on the car.
    would be nice to hear some suggestions. seems like if it aint an s3 its not worth reading about. please don't let that be the case.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    My driver's door used to rattle with a very similar, metalic-like, sound. It turned out to be one of the large bolts (16) that hold the side reinforcement bar (5) was lose - 1 minute later the noise was gone. See vagcat.com for a diagram of the door.
    Without actually removing the interior door card and checking it, it's difficult to diagnose it further though. Try checking the link above for a diagram of the door cards and how to take them off for further ideas.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Mine used to rattle too. I took the door card off and had a look and found loads of shards of glass sitting in the bottom of the door where the passenger side window had obviously been smashed in the past.
    You need to get the door card off and take a look mate.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Mine squeaks like a weee little mousey. Squeak, squeak, squeak.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by HTC View Post
    Just poke some cheese into the door as he's just hungry and wants his dinner!.
    Squeek gone in no time I'm sure.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Now my doors smell of feet......poooeey!
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    Guys... Thanks you all very much for the informative AND funny info. To say I am impressed is an understatement.
    I am leaving to go to kent now. I will post back once I have had the door card off and sorted the problem as found.
    No cheese required my door doesn't squeek... But if it did only the very best "m&s/tesco finest selection" will do for my mouse trap. LMAO.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Did you know that mice can't actually eat cheese. It gives then diarrhoea. The best substance to catch one is grated chocolate.
    Every day is a school day :-)
    ruairi83's Avatar
    Dec 2007
    684
    il send you guide how to remove door card mate.
    Essflee's Avatar
    Mar 2008
    1,995
    I would definately check the bolts at either end of the door first to check they are not loose, mine were which causes the side impact bars to rattle when you shut the door...
    I'd check here first before removing the door card...
    revo'd
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    Solved... Turns out it was the side impact bar bolts... I didn't need to take the door card off after all.
    Thanks all.
    I also managed to run a full scan with vag-com; I now know that the car most probably needs a new central convenience module. That would explain the dodgy alarm/key remote and the ignition not disabling the alarm.
    Or does it?
Tags for this Thread
