Volks AutosChris Nott
    Sep 2009
    10
    ELECTRIC WINDOW JAMMING WHILST GOING UP!
    hi
    i have a 98 a3T and my drivers window has developed a problem whilst going up! it doesnt move it gets stuck but goes down fine!
    anyone got any info how to fix or anything would be very greatful
    thanks ben
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    The clips on the window regulator have broken. Causing the window to shift as you lift it and kicking in the anti-squeeze.
    Common as muck problem, search and you will find many threads!
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    As Tom says above.... you need these higher spec ones
    http://cgi.ebay.co.uk/Genuine-Audi-A...item255802878f
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Sep 2009
    10
    thanks chaps, can u not just grease the originals up?
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    no as they arent gripping, had same problem with mine. if the window comes up a little then goes back down again then its almost definatly the clips
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    Here is a pictorial guide of how to fix. No need to buy parts of eBay - your dealer will be cheaper and they stock the 'upgraded' metal and plastic parts referenced. The resellers on eBay are just ripping people off (like the 'Show your true speed on your aircon' for 99p (codes are free on the net) or even worse, the 'Seat Cupra front splitter for only 45' (that's a 22 part from a Seat dealer)) just because it's on eBay doesn't make it cheap.
    http://www.piglet-net.net/tech/cars/a3-window.html
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
