Sky InsuranceVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 73
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    Remap Devastation :(
    Finally today arrived! was up at 8am dead made it to Auto Glass by 9, Windscreen fixed by 10!
    So that was done! and the trip to get the "beast" mapped was started!
    Got to my garage and had to wait for an hour for Custom Code to send the map to guy to go on the car, so went a drive upto the bentley garage for a look about for a bit.
    Went back down and the map arrived! took 30 mins to apply the map everything went smoothly!
    Guy took it out for a test drive and as he went to pull onto the main road we hear like an almost pop! He brought back in straight away and it was ticking pretty bad. He wasnt worried as he thought it was a typical coil pack problem, but I told him Iv just had 4 new coil packs and a new MAF etc
    So he checked my timing belt and it hadnt slipped, then he done a compression check! Cylinder 2 and 3 are down 30% he says!
    Had to leave the car with him and he's gonna try get to it tomorrow
    Anyone had this problem or any to whats up?
    Audi S3: BAM 225 Standard =]
    | Cupra Splitter | Forge 007P | KnN Panel | 40mm Koni's | Custom Tie's | HEL Lines |
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Hope its nothing serious Stevo
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Strange one ?...as the car was fine when it went in?....the compression could of been the same prior to compression check ..what was compression in the cylinders when he checked it ?...Tapping noise could be hydraulic tappet issue which in turn could cause compression issue to a certain degree..I would start at what they have done with map ...what was the power you were doing for , was it standard generic code or live mapping?..do you have any other engine mods?
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    I dont know what the compression was I didnt see, but I think he was just by the 1 cylinder as the 1 one was a higher reading than the others... I'm no mechanic! lol
    Yeah it as a standard stage 1 Custom Code, I asked him if it might have anything to do with the remap and he said no cause its a mechanical noise and I asked him if it maybe anything to do with the timing cause the map changes timing etc and he said not while its sitting not doing anything.
    No other engine mods, the only thing I changed on my car was my dump valve, fitted it in reverse last night to see what that stupid tinging noise as all about but it ran fine and all this morning it ran fine.
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    The money is there to sort it, was just really gutted cause I was more excited about today than I was at 8 years old on christmas eve! Couldnt even sleep lastnyt!
    But thanks voorhees, I'm hoping its nothing serious as the FMIC and boost guage ill need to wait
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Quote Originally Posted by StevoS3 View Post
    Is it not down to them as you drove it there so the car wasn't broke in the first place.
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    But does does the map not need to have caused the problem?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,494
    Quote Originally Posted by voorhees View Post
    If the map was the cause of the fault, then yes, since the guy didn't even make it to the main road, you would have thought it's the car at fault. It's a close call on whose to blame for something like this.
    Hope it gets sorted out soon Stevo, the remap on an S3 really makes your day on the way home!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Sounds to me like a really bad case of coincidence. Hope it gets sorted cheaply for you.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    It wouldn't of been the map as you said he was pulling out onto the main road, unless he was absolutely gunning it but even then it shouldn't cause any harm.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    Where do you think I stand with they'm covering the costs?
    I mean if the map caused it, the guy will more than likely say it was going to happen anyway, just would have taken more time. But I suppose he'll have to find out what happened first.
    He thinks it might have something to do with a chain of some sort, something to do with a tensioner that controls the chain. Not sure as he was talkin to him self more than me. He says worst case it'll be around 700 if its what he thinks is wrong with it
    Thanks for the support guys!
    mad max's Avatar
    sixth gear
    Jul 2006
    beyond the thunder dome
    335
    was it ticking at all before you took it for the map
    S3 TUNED AT MRC
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    not atol mad max
    Westy's Avatar
    Dec 2008
    17,272
    Quote Originally Posted by mad max View Post
    The 1.8 20v turbo engine ticks like crazy when it's ok anyway so it would be difficult to tell
    S3 Build Thread
    mad max's Avatar
    sixth gear
    Jul 2006
    335
    ticking noise could also be caused by a broken piston ring
    S3 TUNED AT MRC
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    yeah I thought that. I know the engines are a bit tickety but this was like I was running on 3 cylinder! not quite as bad but it sounded like and old fiesta and we all know how bad they can sound.
    mad max's Avatar
    sixth gear
    Jul 2006
    335
    you do mention a tinging noise before you went for the map could this be the same noise?
    S3 TUNED AT MRC
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    I meant the noise that I get from 007P DV, because I've fitted it reversed I get that noise. Dont like it thought and once this is sorted I'm going to put back in the normal possition.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    hope you get it sorted mate what ever it is.... i dont think from what you say that you can blame the tuner..... he will have only applied the map to what was already there, and its a map thats tried and tested....downer is that remapping often finds weak spots - really hope its cheap easy fix for ya
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,354
    I hate to say it mate, but a loud mechanical ticking sound and reduced compression between 2 and 3 points ot a blown fire ring between 2 and 3 to me....
    when the Mini HG pops it sounds exactly like that and looses all power.
    A remap is very likely to cause a dodgy headgasket to pop, as obviously you're pumping a load more boost into the cylinder. Head gasket failure is a very common downside to raising the boost on turbo engines, I'm actually really surprised the 20vt engine doesn't suffer from it all that frequently
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    yeah I know but its always worth a try
    Ill let you guys know whats happening when I find out tomorrow, Monday...
    Fingurs Crosd!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,354
    in addition to my last post, which was incredibly blunt, I really hope for your sake that's not the case mate!
    Best of luck with the diagnosis, hope it doesn't cost too much to fix!
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    Much you talking?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Nick, sounds like his car hadn't even got to the open road yet to make any boost.
    I think this is a case of incredibly bad luck. Like Stevo says, you'll have to wait until you know what's failed to know the culprit.
    Total bummer, good luck with the fix.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    HTC, I see you're based in Crawley now. Shouldn't be too hard to spot your yellow A3, if that's what you're still driving...
    S3KO4's Avatar
    Aug 2009
    London
    850
    Don’t like to point the figure, but if you have your car going for a remap, shouldn’t they have find out whether it is healthy to handle the map! other wise why go through all the heavy cost and headache, I remember when I took mine to AMD Essex they tested it, then drove it to make sure nothing was abnormal before they uploaded any files, I know that some other companies do even more extensive check outs before they touch it. we all can assume it's bad luck but at the end of the day they had it in their hand and it has been working ok before that, and these coincident are becoming too popular at the mapping centre I just wont buy these excuses, after all you pay a good price to get a good power delivery that will be reliable and wont empty your pocket. I hope it all works out well for you...
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
  28. #27
    Westy's Avatar
    Dec 2008
    17,272
    If its the HG that's gone then they wouldn't pick this up in a test before it went pop, its just some serious bad luck!
    S3 Build Thread
  29. #28
    RIP S3dave
    May 2004
    nr Glos
    7,153
    you should'nt be - its a metal gasket and supports >500bhp levels..
    remap and head gasket failures are uber rare..... incorrect coolants used and corrosion is more likely head gasket failures..
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  30. #29
    RIP S3dave
    May 2004
    nr Glos
    7,153
    sounds like some serously bad luck on this one
    cc1 maps are on 100's of cars with no engine problems..
    usual weak points post remap (everyones not cc) is coil packs can expire and blow out the spark from the increased cylinder pressures.
    other 1.8t failures i have seen are valves, and cam belt/tensioners etc
    mechanical failures are not software else they would be popping left right and centre, especially on code which is stable and running fine on many other cars
    I feel for everyone involved.
    unlucky dude
    bill@badger5.co.uk
  31. #30
    Sep 2009
    Essex
    2,366
    and in any case, compression being 30% down means mechanical damage pure and simple (either that or user error), which too could be possible given that it sounds like the new map was put on the car without any checks before hand
  32. #31
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    i know for a fact that JBS checked mine thoroughly before mapping and id be suprised if one of their dealers were to fit without such checks...they go without saying
  33. #32
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    Id explect them to do these checks too, prior to any work carried out, did he make you sign anything?
    I know that I had to sign something when my remap was done, but that may have been for the RR..
    Talk about a scare.. I drove 250miles to get my remap and RR and half way through the RR. a huge cloud of white smoke and a bang happened, and i thought id have a long chat with mr RAC on thw way home and a nice bill..
    Luckily it was just my old intercoller pipes lined with oil, and my car had never been thrashed that hard before.
    Cars:
    Now: Audi TT Project car but looking for An S3 Project.
    Past: Audi A5 3.0 V6 TDI 300BHP 481 lbft
    Past: Audi S3 MTM 345BHP
  34. #33
    RIP S3dave
    May 2004
    nr Glos
    7,153
    fault code checks are usually the norm, not full compression tests
    this is a rare failure
    these cars are getting old now, and the cars histories are probably not known
    might have fsh, but if its avs, then its worthless anyhows imho - seriously coked engines when they have been on variable servicing.. on the avoid list if I were looking to buy one
    bill@badger5.co.uk
  35. #34
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    If you heard an audible pop, and it's running like a bag of plop, has a boost hose not just come off? Sorry to state the obvious but it doesn't seem to of been mentioned... Or maybe one of the intercoolers couldn't deal with the extra boost and has cracked...
    I have heard that 'pop' so many times popping boost hoses off....
    Could of been than your compression was down before and it's purely coincidence....
    Homer Simpson
  36. #35
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by RyanA31.8T View Post
    R tech by any chance?
    Homer Simpson
  37. #36
    Westy's Avatar
    Dec 2008
    17,272
    By the sounds of it the guy didn't even get to put the extra boost through the system as it went pop before they got on the main road!
    S3 Build Thread
  38. #37
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Hmmmm, depends though as to how much load was on the engine etc. Was getting up on to the main road up a incline, did he blip the throttle... I agree it's a less likely scenario, however sometimes the right answer is the simplest/most obvious one.... Just sounded (from the description) like that may of been the cause...
    Homer Simpson
  39. #38
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    i am with him, just bad luck is all
  40. #39
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Sorry to hear about this steve. Nothing prepares you for bad news when it relates to your own car. I've had my fair share of bad news with mine also.
    This ticking noise...and the Re-map guy saying about timing chains, how bad is it? Mine had a top engine rebuild with new parts to sort a problem with the timing chains last year. Costly too. Variable service intervals KILL the 1.8T engine. Why on earth Audi said to do it in the first place is beyond me. The engine internals just aren't built for the job of lengthy oil changes. The oil return pipework is a joke!!
    Keep us up to date matey, be good to actually see the main cause of this problem!
    G
  41. #40
    RIP S3dave
    May 2004
    nr Glos
    7,153
    AVS is the issue, the oil system works a treat when its fed and kept with clean oil
    bill@badger5.co.uk
