AH FabricationsSky Insurance
Thread: Fault codes
    Oct 2009
    178
    Fault codes
    fault codes with vag!
    once the problem has been fixed, do the codes need to be reset in order for the part to function properly
    i am changing my my front lambda senser, said it is nackerd on vag,
    so today once i replace it should it work properly or do i need to have the codes reset
    any suggestions on the best way to replace, it looks a pig to get into with a spanner, i have big arms and hands to.
    Ross_S4
    Aug 2009
    Dundee
    718
    The fault codes being present don't stop a component from working correctly, rather that if something malfunctions and throws up a fault then that information is just stored elsewhere in a memory bank.
    IIRC, if a part registers a fault then works correctly over the next so many ignition switch-ons that that fault is then cleared from the fault memory anyway.
    Oct 2009
    178
    great
    thanks
