Monster MotorsportBadger5
Results 1 to 40 of 40
Thread: FORGE 007PA
    Sm3g's Avatar
    STANDARD S3 (225bhp)
    May 2009
    leeds
    64
    Smile FORGE 007PA
    evening everyone!
    i know this has prob been covered loads of times, but i am interested in changing the standard diverter valve on my 225 s3,am i right in thinking this is the one to go for that dosnt create loads of noise,and also keeps the turbo spinning between gear change???
    also iv heard some people changing the springs in the forge ones if they are wanting a remap,would i also need to do this if i wanted a remap in the future?
    CHEERS!!!!
    http://cgi.ebay.co.uk/Forge-FMCL007P...item35a56a6c8d
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    Yes correct 007p is a recurc valve so literally no noise(can be heard a little if running a aftermarket panel filter)
    Also helps turbo spool up.
    Yellow spring is recomended when you remap the car as this will cope better with the higher boost pressure
    tried to pm you but you dont accept pm's..??
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Yeah the 007pa is the one to get.
    Alot of people tend to stick with the standard green spring even after remapping but you can get yellow springs once remapped, ive got 2 greens, 2 yellow, 1 blue and 1 red in the garage lol.
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    can you tell if your not using the right spring? if so how?
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    Sm3g's Avatar
    May 2009
    leeds
    64
    CHEERS LADS,IL GET ONE ORDERED TOMOZ AND FIT IT AT THE WEEKEND,AND IL JUST GET A NEW SPRING WHEN I GET ROUND TO GETTING THE CAR MAPPED LATER IN THE YEAR,I TAKE IT ITS JUST A SIMPLE SWAP OVER?
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    you will find a yellow will hold better peak boost as green(standard) is basically just for standard boost set up
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    s3bam thats not true, alot of people said the green spring held better and felt more torquey/responsive.
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    ive sent you a message through youre profile..
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Who me?
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    VAG engines arent to bad with springs unless running say 24+ the other example focus rs (run same valve) if youve got the wrong spring in they will run like sack of ****e..!!!
    In all the tuned vags ive had always ran a yellow spring on stage 1/2
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    Forge say green or yellow? I would change the spring in mine but she seems sweet as a nut plus there 11 a spring so balls to that!
    http://www.forgemotorsport.co.uk/con...duct=FMDVSU110
    Cheers Matt
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    do yaself a favour....find the cheapest one on the net then approach ya local supplier and mention that price....JBS reduced theirs for me and i saved a tenner IIRC.... better in your pocket
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,284
    For a mapped S3 the best spring is the yellow one and depending what boost your running you may also need some shims.
    http://www.dpmperformance.co.uk/forg...ve-p-2909.html
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    The spring shouldn't make much of a difference if you run the 007 in the same position as the standard bosch DV. If however you reverse the 007 DV the boost pressure is then pushing against the spring and this is where the spring makes the difference. I did some diags with VCDS with my 007 in normal position and reversed with a yellow spring and that was peaking and holding 22PSI. The only difference I noticed was that when logging in the normal position the boost would climb ever so slightly quicker than in the reversed position. You also get a bit more noise in the reversed position but its an annoying whistle more than a pishhhhh noise.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by DPM View Post
    Is this the item Damien? http://www.dpmperformance.co.uk/forg...it-p-4844.html
    If so, can we get forum discount?
    Homer Simpson
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Westle - I'm running my Forge DV reversed. What spring should i be using?
    Also, what are these shims about in the DV? DPM sell them in the DV spring kit.
    Jay
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by DJ_Troopa View Post
    Jay
    The shims are to allow you to make your own spring effectively. If you want to run a stronger spring than a green, but not as strong as a yellow, then you can add a shim to the green spring to make a happy medium...
    Homer Simpson
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,284
    We already have the 007P's reduced Welly.
    DPM Performance
    T: 01207 561606
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I meant the spring kit for the 007P mate...
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,263
    With a stage 1 remap i've found that a yellow spring will hold 22psi fine with a yellow spring. I've never tested with a green spring but some have said that the DV can creep open slightly with it at high boost.
    S3 Build Thread
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Blimey, i thought you stick a DV in and you're all done. Never thought about these shims and springs! I've got a stage 1 map with reversed 007p dv. What spring should i use and how many shims should i use? Just want to get the best out of it!
    Westy's Avatar
    Dec 2008
    17,263
    If your running in reverse a yellow spring will do the job. If you run it normal I think green will be just fine.
    S3 Build Thread
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Cheers Westle! How about the shims?
    Westy's Avatar
    Dec 2008
    17,263
    I wouldn't worry about playing about with the spring too much. As long as it holds your boost and doesn't leak across the rev range you'll be fine.
    S3 Build Thread
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,284
    We wouldn't be able to do anything extra on the tuning kit, sorry.
    DPM Performance
    T: 01207 561606
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    I seem to lose a little bit power in high revs. Just had a full exhaust system done which has helped this alot! But i'm thinking could spring in the dv affect anything?
  28. #27
    Westy's Avatar
    Dec 2008
    17,263
    My VCDS logs show that my boost starts to drop off at around 4500rpm and is at its lowest (16psi) by the time I reach 6000rpm! I've logged it with normal DV and reversed and they are both the same. I can see that my boost is tailing off because the fuel is leaning off at the top of the rev range. I think a silicone TIP and a FMIC will sort this out. I should think yours will be a similar story, I would doubt the spring would be the problem.
    hope that helps
    S3 Build Thread
  29. #28
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Yeah i know what you mean. After watching the video on the Forge site of how the standard TIP collapses, i realised that could be the issue!
    Video on this page just in case you haven't seen it...
    http://www.forgemotorsport.co.uk/con...oduct=FM225IND
  30. #29
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    dont be too concerned about the TIP collapsing under load....we are yet to find a car that does this...... most are either re-enforced already as OEM (with some sort of metal) or they are very robust rubber..... silicone TIP will give a slightly better air flow.... but isnt something id pay more than 70 for
  31. #30
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    whats the difference with reversing the dv? do you mean off the cold side?
    -AUDI A3 1.8T-
  32. #31
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Nope, it means to take the DV out, and turn it on it's side basically so that the pipes are the opposite way around than they were initially. Makes no performance difference, just a bit more of a din. Forge even say you can run it either way round depending on your preference...
    Homer Simpson
  33. #32
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    oh right might have to give it a go! i didnt realize you could do it either way! does it make a noise if you do it in reverse
    -AUDI A3 1.8T-
  34. #33
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,284
    Yeah it makes a darth vader kind of noise one way and more of a high whoosh the other. Don't think it makes much difference but always thought it's best to keep it the correct way personally.
    DPM Performance
    T: 01207 561606
  35. #34
    Westy's Avatar
    Dec 2008
    17,263
    The boost runs through through the valve differently in the reverse position where it actually pushes against the spring and can open the valve if the spring isn't strong enough. In reverse you get a girly hi pitched whistle noise when you let off instead of the whoosh noise you get normally.
    S3 Build Thread
  36. #35
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    oh we don't like girly whistles do we
    whooshing is the future...you heard it here first!!
  37. #36
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by 1animal1 View Post
    S3 Build Thread
  38. #37
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    also.
    I only like high pitched girly screams in one scenario. As Stiffler said "Hit those high notes baby"...
    Homer Simpson
  39. #38
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    Quick question with regard to spring choice, if you were to fit a DV with yellow springs on standard S3 would this have a negative impact? iam thinking as to having a remap in the future, if the car would run on with yellow springs then could save money buying that straight away?
  40. #39
    Westy's Avatar
    Dec 2008
    17,263
    It should run ok mate. The springs are only 10 so it's not going to break the bank.
    S3 Build Thread
  41. #40
    clacton on sea,essex
    217
    Hi i have a audi a3 1.8t 205.8 bhp with a pipercross panal filter 007 forge valve what spring should i use i have been using the 1 it came with ???
