Badger5AH Fabrications
Results 1 to 10 of 10
    JPT
    Jul 2006
    12
    Filling the arches..........
    What size wheel will fill the arches of a 2002 s3 225bhp? I would like 18" wheels but I haven't got a clue about all of the other dimensions like the width of the wheel and the tyre profile.
    I wanted to avoid using spacers if possible.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Use spacers, the S3 is over tyre'd anyway and I suspect the only way to get it how you want it to the use 3 piece wheels to get the balance of ET and wheel width right as the rears will need to be wider than the fronts to get them to fill the arches properly.... limits your choices, buggers the handling and more expense than it needs to be... IMO of course..
    Spacer wise, I run 10mm front and 15mm rear.
    <tuffty/>
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Likewise.
    Got mine from PW Motorsport (site sponsor I believe) for 100.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    If you don't want to use spacers, then you need to find wheels with a low offset of say ET20-25 for the same effect as running 10-15mm spacers. After market alloys are usually offset ET35 to cater for many models of car.
    Sep 2009
    worcester
    1,097
    got 19 x 9" rims on mine, spaced out from hubs, not lowered and these fill the arches very nicely, i wouldnt lower it on these rims though, arch rub on rear from going over bumps and having passengers in the back and would get full lock rub on the front
    the ride is not that harsh, but i do get a fair bit of road noise coming through even with all the sound deadening audi put in, but it doesnt bother me
    JPT
    Jul 2006
    12
    What size wheels would you suggest then if I was to use spacers?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    Quote Originally Posted by jonny taylor View Post
    Sticking with 18's 18X8's with 225/40 rubber and and offset of ET25 is what you are after. Most wheels in this size is usually ET35, and 10mm spacers will make it ET25, you can put 15mm spacers on the rear to get ET20 which is what some members are running. If you can afford a set, you can get a set of BBS CH in 18X8.5 with 225/40 rubber, and these come in ET25 or ET30(don't remember, due to the rim width, and that will fill the arches nicely without the need for spacers.
    JPT
    Jul 2006
    12
    Thanks for the advice.
    The above sounds great except I don't fancy that style of wheel!
    Was thinking of a multi spoke type, anyone no of any in those fitments?
    cheers
    JPT
    Jul 2006
    12
    Would these fit?
    genuine BBS calito accessory
    these are the details on the paper work
    BBS RT242 1246098 8P0 071498 V0 072
    ET54 71/2 J X 18H2
    They are on ebay
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    Would these fit?
    ET54 71/2 J X 18H2
    They are on ebay
    No they won't fit. If you look at the second string of part numbers, it starts with 8P0, which would suggest these wheels are for 8P fitment, which is the wrong stud pattern for your car. You need 5X100 with an offset of ET25-35 ideally, those would be 5X112 stud pattern, and the offset of ET54 is too high, the wheel will catch your suspension.
