Volks AutosSky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 62
    fran-s3's Avatar
    1,090
    Angry Hate my S3!!!!(I LOVE it really)
    Bloddy thing is driving me crazy, I'm thinking about selling it now! Raaaaaaaaaaaaar!
    Had this annoying knocking coming from the front offside while going over rough road surfaces... it's not constant. Tried to ignore it but it's got to a point that i can't now! So far replaced front anti roll bar, and bushes. (After I inspected my roll bar and found massive cracks in it, so it was my analysis) And yep sound still there still there! Took it to a specialist Audi/VW dealer who said it actually looked fine under the car but did see some slight play on the top mount he admited he wasn't sure it would cure it. So he replaced them today and guess what... it still knocks! I suspected my shock absorber but he said my shocks looked fine, not leaking and I've done a shock test by bouncing it up and down and no creaks at all. SO ANNOYED!!!
    He's now suspecting steering rack and the gaiter or something? What's that? I don't even know what a steering rack it, is it susspension? Isn't it supposed to whine or something on full lock if it's the steering rack I'm sure I've read somehwere? Well mine doesn't and the steering seems fine. So bloody annoyed with it just can't afford to keep it now.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Fran my shocks looked fine when i had my knock too, it was the last thing i changed, when i did get them changed the stupid knock finally went, i would still say its your shocks bud, the oem shocks are quite poor anyway so changing them would only make your car handle and ride alot better than it does now.
    fran-s3's Avatar
    1,090
    Thanks for the reply. Hmmmm really? Dam it I just forked out on a top mount. I don't get a crashy ride or anything though. raaaaaaaaar and you have to do them in pairs don't you?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    The top mounts can't have cost you alot surely? Yeah you got to to them in pairs bud, do you find that the knock is less after you had work done then it comes back? When i had work done because there was no weight on the standard dampers when i dropped the car it was quiet then once it settled the noise was back. Once i got the new dampers all was sorted and the ride is so much better now, what mileage has the car done?
    Bignick's Avatar
    Jul 2008
    Kent
    165
    So how much do you want for it?
    The light that burns twice as bright , burns half as long.
    fran-s3's Avatar
    1,090
    No but the labour to fit them... Just I was allready stung by the roll bar and bush and labour few months ago. This little fiasco has cost me 100's and I'm still no where with it which is the most frustrating thing.. No knocks exactly the same. I'm on standard suspension always have been. She's on 94k
    Bignick's Avatar
    Jul 2008
    Kent
    165
    Euro car parts do OEM shocks well cheap and fitting aint hard took me a while but it was a learning curve. definatley worth doing. Dont follow a haynes manual, they make it look well hard.
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    spring isn't cracked is it?
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Changing top mounts would have uncovered a cracked spring, if you are on a budget go for the oem dampers, the weitec dampers what i have are 150(pair), don't sell it bud, you'll find the knock gremlin soon!
    S3KO4's Avatar
    Aug 2009
    London
    850
    just to put your mind at rest a bit, I have the same sound from the car, I have changed the steering rack that was damaged otherwise, and the bushes, but no joy, and always thought it might be the shocks, but I aint bothered any more I have had it inspected fully for safety reason and all seemed well, so let it make that knock if it wants to. the bottom line is you shouldn't let something so tiny to make you feel annoyed that bad. good luck and keep us updated
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Jun 2003
    World of my own
    9,813
    Definately wouldn't have thought it was the steering rack, so I'd find another VAG specialist if I were you. The rack is just a box that transfers the circular motion of the steering wheel into the left/ right motion needed to move the wheels. It may groan or leak but won't knock.
    Alex Turner
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I am not sure if the S3 rack is the same setup as the A4, not looked tha hard. However there are inner joints available for the A4 as my rack started knocking/rattling. I have the parts sat here ready to fir once i can see the drive again
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    You haven't wasted any money though mate. You said your ARB was cracked so getting a new one is an improvement, also I found replacing the wishbone bushes made the handling much crisper. Dont look at it as a negative because every part you replace is a step closer to a sorted car.
    Dont worry about the knocking mate, I get the occaisional knock from my shocks and I will replace them when I can afford too. If I worried about every little knock and creak I had on my car I wouldn't be able to sleep at night
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Westle View Post
    I hear that mate. Since buying my S3 (cheap all be it) I've had the following to replace:
    Battery, Alternator, 2 Coils, repair coil wiring, 2 rear shocks, Wishbone bushes, NSF Inner CV joint, 2 tyres & rear wheel bearing.
    Ouch.
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,273
    Ouch.
    Pah that's nothing
    I've had the following:
    New thermostat
    2 new tyres
    New drivers door lock
    New rear ARB
    1 coil pack
    Changed wishbone bushes
    2 new wheel speed sensors
    front bumper, bonnet, and roof re-sprayed with new roof rail
    Reconditioned central locking pump
    Alarm wiring fixed
    New bose amp
    New windscreen
    New wiper arms/blades front and back
    S3 Build Thread
    S3 Owner
    Feb 2009
    Aberdeen
    414
    I'm going through the motions of getting my knocking sorted.. Only coming from the front right and i can feel it in the pedal when i go over any sort of bump in the road.. Had the ARB links replaced to no avail, will get my mate to have another look when its in for the service next month. As several folk have said, dont let it get you down too much. Im a perfectionist and i hate that my car is doing it but as long as its road worthy and not dangerous im just gonna do the same as you, replace part by part until its sorted. My car is 2001 so replacing 9yr old suspensions parts isn't the worst thing for the car really..
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Pah that's nothing
    New thermostat
    2 new tyres
    New rear ARB
    1 coil pack
    Alarm wiring fixed
    New bose amp
    New windscreen
    Dude. Thats incredible. We should have some sort of award for you!!! Mucho Respecto. I've nearly burnt mine after all the problems, you must have the patience of a saint....
    I'd like to add I've only had the car a month!
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,273
    Mine is all within a year so you are worse off than me so far
    The problem I have is every time I want to upgrade something, something else brakes and my money goes on that. For example, I was about to buy an iPhone incar kit with bluetooth when my bose amp blew, 160! I then wanted to put away 200 towards either a fmic or new shocks and my windscreen cracked so I bought aero arms and blades for 130 and windscreen insurance excess was 70.
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Again, I feel that. I've got a FMIC sat at home waiting to be fitted, however with having to spend 1.2 million on everything else, I can't afford the pipework this month!
    It's torture I tell you, the cooler is sat by my telly saying 'fit me, fit me' with a sad look on it's little cooler face. Gotta get the S3 sorted and the A3 fixed and gone first though.... then we're off!!
    Homer Simpson
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    Just to make you smile, the FMIC will do nothing for performance in this weather, and will just be a bit of bling for your front end. It's darn cold out there! ... The FMIC can wait.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Thanks Jo, thats made me feel much better and I know you're right....
    I just hate having things lying about if you know what I mean.
    Homer Simpson
    fran-s3's Avatar
    1,090
    Quote Originally Posted by 5ean View Post
    That's exactly how mine is! I just hate spending money and thinking 'hmm is this going to sort the problem or will I have just wasted more !' Thanks for the comments, seems like I'm not the only one, just feels like it at the moment. True it did need a new ARB... I know it's only a knocking and I should try and ignore it but when it's susspension it's kinda worrying! When I get into my mates older cheaper cars i.e pandas lol, cavaliers, fiestas etc and there's sound fine and I have a supposidly well built Audi it makes you think wtf? Fair enough it is 9year old suspenssion granted...
    AnyMac is that what the steering rack does? Just the left and right movement nothing to do with suspension? My mech seems to think the noise is coming from that area but I can def feel some slight vibration through the pedal and only makes a clunk when going over something rough on the road, especially on the right tyre if I go over something on that side. No noise or anything from the left. Could my right wheel not be balanced right or be kerbed somehow? Although I have no vibration through the steering wheel... cutching at straws now. May swap them over at weekend anyway. My steering is fine on full lock and doesn't whine. Hmm think I need to find another VAG specialist.... Have bounced the shock and there seems no sagging though, isn't that the sign of a worn shock?
    So now im thinking do I gamble another 100 next month on whether it sorts it.. Well think im gonna risk it and if not it'll be in www.pistonheads.com in Feb! Just hate spending money and not knowing if it's going to sort it. There's just nothing obvious under that car showing anythings wrong, even I've looked at it. Sorry for the rant guys and thanks, your comments have helped actually.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Good, glad you feel better about it. Knocks are annoying as hell! Have you though about it being an inner CV joint? Mine was busted and clucking away over bumps etc... Problem being that it could be a million things.
    Homer Simpson
    fran-s3's Avatar
    1,090
    Cheers Welly, so many people say different things mate I just don't know. My mech had a proper look over all the parts and inspected them as he took them off to replace my top mount said it all looked good apart from slight play in my top mount.
    Westy's Avatar
    Dec 2008
    17,273
    I would like to think that an Audi Specialist would find the actual problem without you having to spend 100 a month just going through all the suspension components!
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Thats fair enough, you expect a mech to know what the crack is.... Hope you get it sorted mate to be fair, I know how annoying problems like that can be.
    It will be the last thing you check... *cough*. Obviously.
    Homer Simpson
  28. #27
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Agreed, maybe time to get a second opinion....?
    Homer Simpson
  29. #28
    fran-s3's Avatar
    1,090
    Hence why when he mentioned the steering rack I was like you what??? And asked about the shock he was adament is was fine. Not saying it is or isn't I was just baffled and annoyed....
  30. #29
    Westy's Avatar
    Dec 2008
    17,273
    Get a 2nd opinion mate because it sounds like your man has gone through the obvious and may be picking things at random! Personally though if he's told me that everything looks fine and is safe I'd try and forget about it and save your money towards buying some new shocks later in the year.
    S3 Build Thread
  31. #30
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    a lot of so called mechanical specialists are no more than part swappers, think its this swap it oh now it might be that swap it. Knocks can be a nightmare to track down.
    Socker swap would be a good idea on your milage anyhow, I swapped mine at 50k and they felt bad imo.
    red to red black to black blue to bits
  32. #31
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I think we're all agreed it's worth trying somewhere else for a second opinion....
    Homer Simpson
  33. #32
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Have you changed the front arb drop links? This was causing a random knocking noise on my s3, I had the arb replaced along with the lower wish bones about 18months ago, then about 12 months later the knocking occured the guys in the TT shop said that the drop links normally go after the arb, what was intresting though was it had gone into Audi for its mot and passed but the drop links wernt picked up then. New drop links have cured the problem.
  34. #33
    fran-s3's Avatar
    1,090
    Quote Originally Posted by mk1chopper View Post
    No can these be inspected visually? Did yours look worn?
  35. #34
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Didnt look to be honest but you should be able to inspect them, I thought the knocking was my exhaust at first, went out for a test drive with one of the technicians at TT shop, and he said it sounds like your drop links as the noise was coming from the front, and then I told him about the arb being replaced. They said they would change them with a new set (they keep parts like that in stock) and then test drive it to check, luckly that was the fault, drop links were about 60 iirc. The knocking was very random and very much like your discription.
  36. #35
    fran-s3's Avatar
    1,090
    Thanks for that. Hmm front drop links, shocks just don't know anymore.... It's crazy!
  37. #36
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    My knocking was the front anti roll bar and bushes
    Pah that's nothing
    New thermostat
    2 new tyres
    New rear ARB
    1 coil pack
    Alarm wiring fixed
    New bose amp
    New windscreen
    Tyes and wipers (and windscreen to some degree) don't count, they are consumables!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
  38. #37
    S3 Owner
    Feb 2009
    Aberdeen
    414
    I got my front drop links replaced for 35 quid and it made no difference at all.. Reading above, might get my mate to have a look at the inner cv joint. Failing that, im just gonna tell him to tear the suspension apart until he finds the problem. Or might stick it to Bavaria Autowerks here in Aberdeen, they are pretty handy with Audi's..
  39. #38
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by ianysm View Post
    Not when the tyres were 2 months old and both got nails in and the wiper arms and blades had nothing wrong with them, I just want new aero ones to go with my new windsreen. So you can remove the wipers then.
    I'm sure next month will bring something else to my list.
    S3 Build Thread
  40. #39
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    If were doing lists:
    Stereo after volume stopped working properly
    Rear xenon sensor
    Alrarm siren
    Front and rear ARB and bushes and lower wish bones
    1 rear drop link
    Front drop links
    1 front spring
    both rear springs
    Rear wiper repair kit (also fitted areo wiper at the same time)
    new alloy (well 2nd hand) - turned out 1 of my avus alloys was a replica so my cars probably had a prang even though its HPI clear
    wheels refurb'd
    thermo stat
    collant bottle (had the coolant level sensor problem)
    ignition barrel
    new drivers side wing mirror glass after the heating element broke
    Brake light switch (behind pedel)
    Battery
    This is over 3 years
    Also had to replace the front discs and pads and rear pads, but dont think this counts as its the same as tyres. I've also fitted front aero wippres to.
  41. #40
    S3 Owner
    Feb 2009
    Aberdeen
    414
    I dont get why consumables dont count? Discs and pads etc are still neccessary to keep the car on the road and are still part of keeping a car? Petrol wouldn't count but to me, everything else does.. Cars eh!
