Volks AutosMonster Motorsport
    May 2006
    Surrey
    175
    Radio, Ignition switch, interior lights
    Hey Everyone,
    I've tried doing searches but the new search setup on here seemed messed up???
    Anyway my problem is:
    Radio isn't turning on/off with the igintion, also the interior lights don't turn off when engine is started as they normally do and only turn off on their usual timer.
    I plugged vagcom in and got: 00849 - S-contact at Ignition/Starter Switch (D)
    31-00 - Open or Short to Ground
    So am I looking for a duff fuse or looking for a poor connection on the ignition barrel. I understand that it is a remote problem but don't know what could be causing it.
    Any help much appreciated.
    Audi S3 2001. Black on Black. OE Sat Nav/Freeview. Bose. 18" Audi/BBS Splits. 10+16mm Spacers. KW Coilovers. Forge DV,tip and intercooler pipes. KnN Panel Filter. Oh and the essential Re-map. GONE
    Jun 2003
    World of my own
    9,813
    Must be open circuit or it would have blown a fuse (Radio S-Kont). Is everything else alright electrically?
    Could easily be just the keyswitch is becoming unreliable. Had mine go on my A4 and it burnt out the starter motoras it was engaging the starter when driving along which it didn't like. It's an easy DIY fix and cheap as well even from a stealer at 20 or so for the part.
    Alex Turner
    May 2006
    Surrey
    175
    Thanks andymac, just come in to report my success and your right is was fuse 37 "s-contact" i was looking for a fuse called remote or at least something to do with radio or lighting.So i'm very happy now as i have my freeview back.
    Jun 2003
    World of my own
    9,813
    Wow, it's never just the fuse!
    Alex Turner
    May 2006
    Surrey
    175
    I know I was so happy when it turned out to be a fuse as the wiring behind the headunit is crazy with all the freeview stuff and old audio leads that are now un used.
Tags for this Thread
