Badger5JMB Retrofits
    Nov 2007
    30
    Cheap Vagcom Cable
    Hi has anyone heard of a company called talktomycar.co.uk they are selling the vagcom cable about Ł25. As anyone heard of them before, if yes can i trust them to buy this very cheap cable which seems almost too good to be true.
    S3 Paul's Avatar
    Oct 2006
    2,764
    There are plenty of cheap vag com leads out there... Ebay is normaly the place most look,
    Ive got one , Most of them dont let you get the full use from the vag com software. I think the real ross tech lead has a chip in that allows the full use of the software,
    If your just checking fault codes and the like it should be fine . are you using Vista on the laptop in question? I think a few people have slight problems with the copy leads and shareware . I may well be wrong though
    Noggy Blue 2001 S3
    Nov 2007
    30
    No mate im using windows 7
    ssbnreso's Avatar
    Sunny Sunderland
    80
    I got a cheap lead off ebay for about Ł9.
    Does the job.
    I'm running vista on my laptop, and a few probs to start but if you run in compatabilty mode as xp and as an administor works fine.
