Badger5Monster Motorsport
Results 1 to 25 of 25
    arsenal_69r's Avatar
    audi a3
    162
    Have I an alternator problem ? (video)
    audi a3
    162
    loads of views yet no replys? as you can tell by the video the car starts sloppy and all rev and petrol counters work up untill the heating or windows are operated
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Try being patient
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Not sure but could be a bad earth somewhere, tricky one
    audi a3
    162
    whats the best way to check the alternator? using a voltmeter? or the best way to see whats wrong
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Something like this would do bud
    http://uk.aldi.com/uk/html/offers/58_4785.htm
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    check your earths
    a multimeter will show a bad alternator, measure voltage before starting and then start car, the voltage at the batt should go up to around 14 ish volts. If it does the alternator is 99% working fine.
    audi a3
    162
    nice one cheers bud, one more thing. do i check the wire from the alternator to the battery yer?
    audi a3
    162
    Quote Originally Posted by Byzan A4 View Post
    check your earths
    nice one cheers also is the earths or the alternator the most likey course of this? just so i can shorten it down and concentrate on that cheers
    Apr 2004
    12,520
    Check volts at the batt, however IMHO there is no way for alt output to have a bearing on this at all. It will more likely be an earth in the car, probably under the knee bolster or similar
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by arsenal_69r View Post
    Think you just connect the black to earth and red to live and see what happens with the light show lol Mark's (byzan A4) more of an expert than me
    audi a3
    162
    how and where would i check the earth and if it is what then would i do? cheers appreciate this alot
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Agree with you chief! The dodgy earth could be under the steering wheel trim
    audi a3
    162
    http://auto.howstuffworks.com/under-...r-problems.htm
    this is the link somone else sent me as it has some signs that can lead to alternator problem and i have had about 3 of the signs thats only reason why i thought alternator
    audi a3
    162
    another quick thing. how would the earth all of a sudden become a problem?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    It's a process of elimination with electrics, when you put any heating device on your asking for alot of voltage, is the car actually going off when you put the heating on full?
    audi a3
    162
    well the first time it done this was when i was driving along the motorway and i pulled over and turnded the engine of and it wouldnt start again it was like a had a flat battery. but to answer your question whilst just the engine is running and the heating fully up the engine is not cutting out now just the dash goin and also the interior light flickering.
    audi a3
    162
    would using vag pick the problem up or?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Its a bad earth
    audi a3
    162
    so what am i to do about the earth then? where would it be and mainly how do you fix it?
    audi a3
    162
    honeslty appreciate the help bud
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I'm not sure which earth it'll be you need to check, just to be on the safe side, just check if your earth on the battery is secure and not loose, could be an easy fix
    audi a3
    162
    ill have a look at my batterys earth in the morning, so best thing probs would be to get it looked over then yer?
    audi a3
    162
    also what ive just thought if it was my alternator or battery the battery light would pop up on the trip computer?
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    FFS just get it tested, KWik fit will do it for free, it could be the voltage regulator within the alternator. There's no point in hunting for a bad earth that might not even be there, it could even be a dry cell in the battery
