Badger5AH Fabrications
Results 1 to 12 of 12
Thread: Door Latch.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Door Latch.
    Does anyone know the part number or other models that i can use the door latch off for my s3.
    The passenger door is getting worse, froze open again today, its doing my tits in.
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    What do you mean by froze open? Is the latch getting stuck??
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Yeah mate, will open then the handle goes slack and the mechanism stays open inside the door so when you close it it doesnt hold shut. takes some warming up, slamming and alot of swearing before itll engage haha.
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Tried a bit of WD40 to lube it up a bit?
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Quote Originally Posted by DJ_Troopa View Post
    This happened to my drivers door the other day, I since sprayed it with a bit off WD40 and not issues since, its not so much a fault with your mech just the fact theres moisture in there freezing, WD should help.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Slamming the door wont help either, if it happens again try to free the mech by using a screw driver
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Thats the thing, the latch that connects to the frame of the car moves, itas the mechanism inside the door, its hard to explain.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    I know what you mean, it pushes down inside the latch, its should spring back up when you close the door locking the latch in place, I found mine was stuck down, but after spraying it with wd and using a screw driver to free it its been fine.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Ill try the wd40 trick, if not new latch, its a pin in the arse, especially if no ones in the passenger seat to hold the door haha.
    S3 Paul's Avatar
    Oct 2006
    2,764
    try and do the wd40 trick after the car has been in a garage or warm place. This may also evaporate ( sorry i can not spell ) the moisture so aiding the wd40 to coat the parts that frost up
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Cheers guys, going to try tomorrow.
    ROB.B
    Jun 2009
    41
    lmao this happened to me the other day when i was in a rush to work. gave it a spray all seemed ok after that
