Chris NottSky Insurance
Results 1 to 11 of 11
Thread: Forge or Bailey
    Rob-s3lv's Avatar
    Oct 2009
    15
    Forge or Bailey
    Hiya I need to get a diverter valve / dump valve for the S3 n get the map sorted its doing my nut in now
    any way whats the better choice forge or bailey
    cheers
    Rob
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I have a Baileys DV30, i got this because i didn't want to mess around with different coloured springs.
    Many members here use the Forge items and don't have many issues, i'd say they were both decent DV's
    Rob-s3lv's Avatar
    Oct 2009
    15
    might sound like im being cheap but im more favouring bailey as its cheaper n if its just as good il get it
    cheers for the reply
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    There's not much in price difference bud, think the Forge are a little cheaper infact.
    Make sure you get the Bailey DV30 if you do end up going for Bailey, DV26 isn't advisable as its not a re-circulating DV
    Rob-s3lv's Avatar
    Oct 2009
    15
    just orderd the bailey DV30 and did work out bit cheaper then the forge one not by much tbh
    did yours fit alright ?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Yeah, the fitting on mine was perfect, can't go wrong really, very easy to fit, what colour did you go for?
    Rob-s3lv's Avatar
    Oct 2009
    15
    went for a black one just so its looks std really
    44
    are these baileys loud or quiet
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    It will be quiet because it's a recirc valve not a dump valve..... i was also led to beleive there are no performance gains to be had over the standard valve..... the only advantage being reliability ... is this true ???
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Sep 2009
    Essex
    2,366
    why dont you guys use the 710n valve? its what the s4 types bang on about all the time and it only costs 23 a go
    considering the OE one lasts 100k miles or so, if you have a relatively standard engine you can get four replacements for the cost of the forge...
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I've got a baileys recirc valve, only cost me 50 from a friend. Can hear it from inside the car, not sure if it can be heard from the outside but it's pretty loud so I think it can.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
