Badger5Chris Nott
Results 1 to 23 of 23
    Oct 2009
    73
    Traction Control Warning Light Coming On
    Hi all,
    I have a 2000 A3 T-Sport Quattro.
    When I go on a journey of more than 15 minutes the traction control warning light comes on and stays on until I swith the ignition off.
    It then doesnt come back on until another journey lasts at least 15 minutes!
    It doesnt flash it just stays lit up.
    Any ideas?
    Could it be a serious problem?
    Car still seems to drive normally!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    Is it the only light that comes on or does the ABS light come on too?
    You could do with getting your car scanned really.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Could be a faulty wheel speed sensor?
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Oct 2009
    73
    Its just the traction control light that comes on.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,900
    longitude sensor
    Oct 2007
    London
    40
    Could be a faulty brake switch. You won't know for sure until you get the fault log from a scan.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Could be your suspension geometry is out, mine came on permantly on my S3 after I had a front spring replaced, after i had the 4 wheel alignment done it went away. But no harm in having a scan done either
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    This is also a symptom of either the G200 (lateral acceleration sensor) or G202 (longitudinal acceleration sensor) being incorrectly calibrated or faulty on facelift models - I think is the same on pre-facelift. Although as others have said get a scan done and see what codes are found.
    2001 A3 1.8T TQS
    1998 A8 2.8 Auto
    Only me
    Mar 2009
    cambridge
    126
    could also be the maf, that was the reason it came up on my qts
    gazsutton's Avatar
    I MISS MY LCR!
    May 2010
    Near Loughborough
    39
    this has happend to mine. noticed it the other day was driving, then went round a sharp corner and it came on.
    restarted the engine and it didnt come on again till the next day, restarted it, and again it hasnt been on since.
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Happend to me a while back and turned out that my haldex control unit was goosed, had to get a new one. Get it scanned then you will know.
    2001 AMK ...Black
    gazsutton's Avatar
    I MISS MY LCR!
    May 2010
    Near Loughborough
    39
    Quote Originally Posted by landopanda View Post
    how much did that cost?????
    Aug 2006
    29
    bringing back an old post as i am pulling my hair out with my issue.
    my 2001 S3 amk engine has the traction control light constatntly, i bought the car with the light on.
    I scanned the car and the only fault was lateral acceleration sensor, electric circuit failure, i have had it scanned by audi and ordered a new lat accel sensor at Ł124. my mate is an audi technician and he fitted the new sensor and "zero'd" it off using vag.com. however the fault code would not clear and the light on the dash stayed illuminated.
    He came around tonight to have another bash at it with an older style vagcom which the instructions he has relate to as the first time he did it he had an updated machine and some modules and measuring blocks had been changed and we couldnt get into the relevant section and follow the instruction presicely.
    anyway old software machine used tonight and still it would not work, the fault code would not clear, he ended up manually coding the lateral acceleration sesnor and the light went out but then the ABS light began to flash and when i drove the car it beeped like mad. the 4wd didnt work nor the ABS. we scanned the car and abs came up clean no faults but the lat accel sensor code was still there even thought the light was off.
    he undone his coding and the ABS light went out and traction light came back on, no beeping but still no 4wd.
    we are stumped at this and he is emailing audi technical for assistance but i have a few questions of my own
    would a dodgy maf cause the traction light to come on? if so, would a dodgy maf show up on a vag com scan?
    would a revo remap cause the traction light to come on?
    i hope someone can help as its spoiling my fun in the car, i love it to bits but not being able to take round abouts or bends safely is doing my nut.
    thanks in advance.
    Feb 2011
    southampton
    229
    i am looking to buy a car with this tc light on .. i have read alot about this but whats the most common problem to fix this
    Westy's Avatar
    Dec 2008
    17,274
    I wouldn't touch that car until you've seen what the fault codes are! It could be anything from a wheel speed sensor (Ł70) to the Haldex control unit (Ł600).
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Dodgy MAF is the most common, however normally comes on quicker than 15 mins.
    My traction control light is always on, as a sensor on the underside of the master cylinder has gone.
    I haven't changed it deliberately as it doesn't cause problems, and it also means I don't have to turn the traction control off manually....
    Lazy I know...
    Homer Simpson
    May 2006
    Lancs
    211
    Does a fault in some part of the system actually disable the ESP or just bring the light up to tell you there is a fault?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    There are quite a few sensors that can bring the esp light on inc MAF
    Feb 2011
    southampton
    229
    when cars first started the light is off . but if you release hand brake and roll it will come on and stay on untill you switch it of and start it again..
    but you roll car and straght away its on again
    Feb 2011
    southampton
    229
    i used to have a ibiza cupra 1.8t and that was maf that caused the light to stay on.
    Westy's Avatar
    Dec 2008
    17,274
    If the light is coming on as soon as you start rolling I'd think it'll be one of the wheel speed sensors.
    S3 Build Thread
    Feb 2011
    southampton
    229
    Quote Originally Posted by Westle View Post
    ok mate cool cheers.. ill get some one to vag com it
    Feb 2011
    southampton
    229
    right i got the car home and where will i find the ecu plug so i can get vag com on it..
