EM TuningChris Nott
Results 1 to 10 of 10
    Oct 2007
    42
    Can anyone help?
    ive got a problem with my car and wondered if anyone could help,its a 2002 s3 , when ever i hit a bump or a little bit of water the rear end is really twichy also the snowflake symbol is always on ,anyone have any ideas ? many thanks
    luke
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    The snowflake will always be on at 5degrees and below, as its cold at the mo, that could be the reason why, have you noticed it to be on above 5???
    Also regarding the rear, have you checked the tread on the tyres, the air pressure, it could be many things...
    Oct 2007
    42
    Quote Originally Posted by nilz18t View Post
    oh didnt realise the snowflake was still at that degrees .will keep an eye on that , tyres are fine and pressures are fine .was thinking of taking it somewhere tomorrow to get it looked at,just needed some ideas .thanks
    luke
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    is the 4 wheel drive working
    S3 Owner
    Feb 2009
    Aberdeen
    414
    I had a similar issue and still do to an extent but i found both rear springs were snapped.. Pretty common thing in the 8L im told?
    Essflee's Avatar
    Mar 2008
    2,007
    Could be a snapped spring,
    Or worn shocks...
    revo'd
    Oct 2007
    42
    Quote Originally Posted by avo2006@hotmail.co.uk View Post
    4 wheel drive is working .thanks
    Oct 2007
    42
    Quote Originally Posted by 5ean View Post
    oh thats not good . will try and get it looked at today .thanks
    luke
    S3 Owner
    Feb 2009
    Aberdeen
    414
    If you jack the back end up you will be able to have a peer in at the springs and feel the base of them to see if they are snapped.. FYI my springs cost me 100 + fitting if i remember right.
    Jan 2009
    344
    I'd check the springs... I had the same symptoms and my rear springs had snapped. I have now decided to upgrade the springs and shocks all round. Will update you shortly.
    Now: 2009 S3 8P3 DSG. Mods: Revo Stage 2+, Full TBE, Autotech HPFP, Revo CAI, H&R ARBs, SuperPro Anti-Lift Kit, Rev D, Cruise control, LED interior lights upgrade, Rear DRLs... SPS & VCDS.
    Previously: 2001 AMK S3, Silver, Revo Remap, Milltek DV, KW Springs & Shocks, H&R ARB.
