Sky InsuranceVolks Autos
Thread: S3 Lower Bushes
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    S3 Lower Bushes
    Merry Crimbo all, hope you all had a good one.
    Investigating an annoying knocking both sides of the motor at the front, it looks like the lower arm bushes are shagged...
    Had a look at lower arms, however I believe you can replace just the bushes...
    This is the one which is shot:
    And this is the bush kit I've found to replace with....
    http://cgi.ebay.co.uk/Audi-S3-Powerf...f#ht_915wt_939
    Anyone else done this, or know if this is right?
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Don't bother replacing those rear ones with powerflex... replace the front ones with power flex and the rears with solid type (not voided) OEM style..
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=130350454038
    <tuffty/>
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Yeah, it's the front that's the problem. So worth doing then?
    My only thought is that I can get two brand new lower arms from Euro Car Parts for an extra 24 quid.... Although my experience with Powerflex bushes has been nothing but good I admit.
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Front pair of powerflex should be about 30/40 and those ebay bushes a tenner or so... Proper S3 arms (different to the A3 remember) are over 100 iirc...
    As your car is an early S3 then you may have the smaller front bushes. Pretty sure Bill keeps the powerflex fronts in or can get them easily at least as they are the same as Ibizas etc iirc
    Powerflex wise, fronts are fine but rears squeeze out and need replacing quite regularly from what I have heard so the solid rubber ones are just as good, cheaper and last longer.
    Its what I have on mine....
    <tuffty/>
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by tufftybloke View Post
    Well, I got the ECP parts finder to fish those arms out from the reg no so I presume they're right. 47 each didn't seem too bad.
    I put a link to the eBay ones I found, a lot more than 30 quid
    Just wondering what's the easiest/cheapest route to go...
    Homer Simpson
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Sorry dude, I've just twigged what you meant by rear bushes! I thought you meant as in rear of the car, not the rear bush of the two on the wishbone! Duh.
    OK, will investigate.
    Homer Simpson
